I’ve recently switched from windows to linux as my main os. So I think its driver related but I’m getting no errors to debug. Any help would be greatly appreciated.
Dev Board - STM32F3 Discovery
Framework - CMSIS
OS - Ubuntu 20.04
Lastest version of Vscode and Platformio
Using the provided CMSIS Blink Sketch with no changes
PS. I’m new to this forum, maybe I posted this on the wrong thread, if so tell me ill fix it right away.
Thanks!
Exact platformio.ini
? The firmware requires that you activate the STM32F3 macro via build_flags
You are running this on the STM32 on this exact board, yes?
YES that’s my board. Here is the ini file config (I removed the other boards)
[env:disco_f303vc]
platform = ststm32
framework = cmsis
board = disco_f303vc
Try adding
build_flags = -DSTM32F3
to the platformio.ini
Does a upload result in “SUCCESS”?
If you have multiple projects opened in VSCode, did you use the project environment switcher to select the right one?
Yes i only have one project open and it does result in success also i added your build flag and nothing changed. Here is the log
Processing disco_f303vc (platform: ststm32; framework: cmsis; board: disco_f303vc)
Verbose mode can be enabled via -v, --verbose
option
PLATFORM: ST STM32 (14.0.1) > ST STM32F3DISCOVERY
HARDWARE: STM32F303VCT6 72MHz, 48KB RAM, 256KB Flash
- framework-cmsis 2.50501.200527 (5.5.1)
- framework-cmsis-stm32f3 2.3.4
- tool-dfuutil 1.9.200310
- tool-ldscripts-ststm32 0.1.0
- tool-openocd 2.1100.0 (11.0)
- tool-stm32duino 1.0.1
Found 0 compatible libraries
Scanning dependencies…
Compiling .pio/build/disco_f303vc/FrameworkCMSIS/gcc/startup_stm32f303xc.o
Compiling .pio/build/disco_f303vc/FrameworkCMSIS/system_stm32f3xx.o
Compiling .pio/build/disco_f303vc/src/main.o
Linking .pio/build/disco_f303vc/firmware.elf
Checking size .pio/build/disco_f303vc/firmware.elf
RAM: [ ] 0.1% (used 28 bytes from 49152 bytes)
Flash: [ ] 0.1% (used 344 bytes from 262144 bytes)
Configuring upload protocol…
AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
Uploading .pio/build/disco_f303vc/firmware.elf
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.11.0-00155-ge392e485e (2021-03-15-16:43)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
xPSR: 0x01000000 pc: 0x080001c8 msp: 0x2000a000
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
==================================================================================== [SUCCESS] Took 0.99 seconds ====================================================================================
