However if I change build_type to release the data seems to be getting corrupted. Essentially I see on my oscilloscope that the interrupts work fine however, the data that I’m trying to send over through SPI is all garbage. I considered it might have something to do with the compiler optimization but it doesn’t seem to change anything.
Expected is a series of individual messages
0x01FF
0x02FF
0x03FF
etc…
Observed is hard to explain, but an occasional glitch, some of the transactions go through fine, and others are not in an irregular pattern (if that makes sense) I would say it’s close to a 50/50.
For sending the data I’m using the ST default Hal layer on interrupt basis. The data itself is coming from an array that I’ve made volatile.
If there’d be a way to properly check whether TX is actually filled as supposed to that’d be neat but since it works while debugging I don’t see a way how
Sorry for the late response, I wasn’t aware it did that internally, so it’s probably better to have gotten rid of it regardless, thanks for that!
The behaviour did change after removing it, the first part
0x01…
0x02…
etc
seems to be correct, however the 2nd byte is not being send over correctly all the time, only the first 2-3 of 8 transmits are good about 40% of the time.
The chipselect, clock etc are all working just fine but the data seems to be getting scrambled somehow.
I can swap interrupts out with polling quite easily, and it indeed works fine when using polling (with my firmware on top of it). I just swapped the interrupt out for the polling alternative function. Is it somehow timing related?
So I managed to find a ‘solution’ for it, essentially I had my SPI baudrate prescaler quite high, 256, I then lowered it to 8 and the issue dissapeared.
