The RingBuffer library has its SERIAL_BUFFER_SIZE definition as below:
#define SERIAL_BUFFER_SIZE 64
I would like to change it to 512 without touching the lib itself.
I have tried adding this definition on build_flags (-D SERIAL_BUFFER_SIZE=512) but it won’t take effect.
Is there any way to make this work without touching the RingBuffer library?
Thanks.
You could give -U SERIAL_BUFFER_SIZE
before -D SERIAL_BUFFER_SIZE=512
a try… it’s a build_flag which cancels previous declarations of a macro, but I don’t know if it will clear the definition provided by the library.
I tried that but it doesn’t work.
Thanks anyway.
hi im in same case but dont find solution
i work on software marlin https://marlinfw.org/
i try to find solution to make change in configurations files.
in this files u have
1: #define name (#define BABYSTEPPING)
2: #define name number #define BABYSTEP_MULTIPLICATOR_Z 1 )
3: #define name letter ( #(define LCD_LANGUAGE en)
so in platformio.ini i had in build_flags = -DBABYSTEPPING for this it’s ok i work
but for 2 et 3 i doesn’t work
i try with this -DLCD_LANGUAGE=fr or
-ULCD_LANGUAGE
-DLCD_LANGUAGE=fr
i have warning the value redefine but not change with the value i want
i work if a made this change in the config files to this
#ifndef LCD_LANGUAGE
#define LCD_LANGUAGE en
and in bluid_flag add -DLCD_LANGUAGE=fr
but i want make change the value without touch the config files
thanks for your help
