I’m getting an error ‘cc_path is not defined’ when I am trying to do a platformio init for a nano.
> pio init --board nanoatmega328 --ide clion
The current working directory /media/TheWild/Chiquita/Devel/Arduino/SSD1306_tes$ will be used for project.
You can specify another project directory via
`platformio init -d %PATH_TO_THE_PROJECT_DIR%` command.
The next files/directories have been created in /media/TheWild/Chiquita/Devel/A$duino/SSD1306_test
src - Put your source files here
File "/usr/local/lib/python2.7/dist-packages/platformio/__main__.py", line 10$, in main
cli(None, None, None)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 700, in __call__
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 680, in main rv = self.invoke(ctx)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 1027[22/406]oke
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 873, in invoke
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 508, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/click/decorators.py", line 16, in new_func
File "/usr/local/lib/python2.7/dist-packages/platformio/commands/init.py", line 103, in cli
pg.generate()
File "/usr/local/lib/python2.7/dist-packages/platformio/ide/projectgenerator.py", line 121, in generate
self._render_tpl(tpl_path).encode("utf8"))
File "/usr/local/lib/python2.7/dist-packages/platformio/ide/projectgenerator.py", line 127, in _render_tpl
return bottle.template(content, **self._tplvars)
File "/usr/local/bin/bottle.py", line 3619, in template
return TEMPLATES[tplid].render(kwargs)
File "/usr/local/bin/bottle.py", line 3409, in render
self.execute(stdout, env)
File "/usr/local/bin/bottle.py", line 3396, in execute
eval(self.co, env)
File "<string>", line 4, in <module>
NameError: name 'cc_path' is not defined
`pip install -U platformio` command
http://docs.platformio.org/page/faq.html
It seems to do it on all three of my platforms so I’m not sure what is wrong or missing.
