I had used ‘sudo pip install platformio’, but after the problem described below, I uninstalled it, and then installed pio from the zip file in the git repo.
The result was the same.
I made a local copy of the .platformio examples, and did: arduino-blink> pio init --ide eclipse --board esp32dev
This worked, and I was able to import the project into eclipse and build it.
I next did: pumbaa-blink> pio init --ide eclipse --board esp32dev
This succeeded, and was imported to eclipse, but no binary files were shown there.
The platformio.ini file has:
[env:nano32]
framework = pumbaa
board = nano32
So I did ‘pio run’ to build the program binaries in the local directory.
The build of FrameworkPumbaa succeeded, but then the tools went on to build FrameworkArduino, which didn’t:
Linking .pioenvs/esp32dev/firmware.elf
.pioenvs/esp32dev/libFrameworkArduino.a(main.o):(.literal._Z8loopTaskPv+0x0): undefined reference to setup' .pioenvs/esp32dev/libFrameworkArduino.a(main.o):(.literal._Z8loopTaskPv+0x4): undefined reference to
loop’
.pioenvs/esp32dev/libFrameworkArduino.a(main.o): In function loopTask(void*)': /home/milton/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:9: undefined reference to
setup’
/home/milton/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:11: undefined reference to `loop’
*** [.pioenvs/esp32dev/firmware.elf] Error 1
My question is: will pumbaa work on the esp32dev board, or only on the nano board? If pumbaa works on esp32dev, I won’t care
too much if arduino works, but you might.
