guys, i want to send the soil moisture and ldr data value using mqtt and send it on json format, and i dont know the code or library i used, here is my code, the dht value is able to send, but the soil moisture and ldr not
please help me
(main.cpp)
#include "ESPAsyncWebServer.h"
// #include <ESPAsyncTCP.h>
#include <definitions.h>
#include <FS.h>
#include <storage.hpp>
#include <auth.hpp>
#include <Hash.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Simple_HCSR04.h>
#include <PubSubClient.h>
#include <I2CSoilMoistureSensor.h>
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String channelState(int numCh);
String htmlProcess(const String &var);
void deviceInit();
void mqttCallback(char *topic, byte *payload, unsigned int length);
void mqttInit();
void mqttReconnect();
String composeSensorJson();
// Replaces placeholder with button section in your web page
Serial.println(var);
if (var == "DNM")
return String(DeviceConfig.DeviceName);
if (var == "APSSID")
return String(DeviceConfig.ApSSID);
else if (var == "APPWD")
return String(DeviceConfig.ApPwd);
else if (var == "TETPWD")
return String(DeviceConfig.TetherPwd);
else if (var == "PUSER")
return String(DeviceConfig.PortalUser);
else if (var == "PPWD")
return String(DeviceConfig.PortalPwd);
else if (var == "MAXSTR")
return String(MAX_CONF_STRING);
else if (var == "MAXSSID")
return String(MAX_CONF_SSID_NAME);
else if (var == "SHAPWD")
return sha1(DeviceConfig.PortalPwd);
else if (var == "FWVER")
return FW_VER;
else if (var == "PRODNAME")
return PRODUCT_NAME;
else if (var == "SELDHT")
return DeviceConfig.Device == DeviceSelect::DHT_11 ? "selected" : "";
else if (var == "SELSOIL")
return DeviceConfig.Device == SoilMoisture ? "selected" : "";
else if (var == "SELPIR")
return DeviceConfig.Device == PIR ? "selected" : "";
else if (var == "SELLDR")
return DeviceConfig.Device == LDR ? "selected" : "";
else if (var == "SELRELAY")
return DeviceConfig.Device == Relay ? "selected" : "";
else if (var == "MQTTSRVR")
return String(DeviceConfig.MqttServer);
else if (var == "MQTTPORT")
return String(DeviceConfig.MqttPort);
else if (var == "MQTTPORTMIN")
return "3";
else if (var == "MQTTPORTMAX")
return "6";
else if (var == "MQTTUSER")
return String(DeviceConfig.MqttUser);
else if (var == "MPWD")
return String(DeviceConfig.MqttPwd);
else if (var == "MQTTPUB")
return String(DeviceConfig.MqttPub);
else if (var == "MQTTSUB")
return String(DeviceConfig.MqttSub);
else if (var == "MQTTPUBSEC")
return String(DeviceConfig.MqttPubSec);
return String();
// Set IP addresses
IPAddress apLocalIp(192, 168, 1, 1);
IPAddress apLocalIpGateway(192, 168, 1, 1);
IPAddress apLocalIpSubnet(255, 255, 255, 0);
uint64_t lastMsWiFiSta, lastMsHb;
I2CSoilMoistureSensor *soil = nullptr;
DHT_Unified *dht = nullptr;
Simple_HCSR04 *hcsr = nullptr;
WiFiClient espClient;
PubSubClient client(espClient);
void setup()
//Serial port for debugging purposes
deviceInit();
// Initialize SPIFFS
if (!SPIFFS.begin())
Serial.println("An Error has occurred while mounting SPIFFS");
return;
loadConfig();
WiFi.setHostname(DeviceConfig.DeviceName);
WiFi.begin();
pinMode(LED_HB, OUTPUT);
// Connect to Wi-Fi
WiFi.mode(WIFI_STA);
WiFi.begin(DeviceConfig.ApSSID, DeviceConfig.ApPwd);
// Route for web pages
server.on(WEB_PAGE_ROOT, HTTP_GET, [](AsyncWebServerRequest *request) {
handleRedirect(request);
server.on(WEB_PAGE_INDEX, HTTP_GET, [](AsyncWebServerRequest *request) {
if (!handleLoginAuth(request))
return;
request->send(SPIFFS, WEB_FILE_INDEX, CONTENT_TYPE_HTML, false, htmlProcess);
server.on(WEB_FAVICON, HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(SPIFFS, WEB_FILE_FAVICON, CONTENT_TYPE_PNG, false);
server.on(WEB_PAGE_LOGIN, HTTP_ANY, [](AsyncWebServerRequest *request) {
handleLoginPage(request);
server.on(WEB_PAGE_SETTINGS, HTTP_GET, [](AsyncWebServerRequest *request) {
return;
request->send(SPIFFS, WEB_FILE_SETTINGS, CONTENT_TYPE_HTML, false, htmlProcess);
server.on(WEB_PAGE_LOGOUT, HTTP_GET, [](AsyncWebServerRequest *request) {
handleLogout(request);
server.on(WEB_PAGE_REBOOT, HTTP_GET, [](AsyncWebServerRequest *request) {
return;
request->send(SPIFFS, WEB_FILE_REBOOT, CONTENT_TYPE_HTML, false, htmlProcess);
server.on(WEB_PAGE_REBOOT_NOW, HTTP_GET, [](AsyncWebServerRequest *request) {
return;
ESP.restart();
// Send a GET request to <ESP_IP>/updt
server.on(WEB_PAGE_UPDATE, HTTP_GET, [](AsyncWebServerRequest *request) {
return;
String resp = composeSensorJson();
Serial.print("RESP: ");
Serial.println(resp);
request->send(200, CONTENT_TYPE_JSON, resp);
server.on(WEB_PAGE_SETTINGS_SAVE, HTTP_POST, [](AsyncWebServerRequest *request) {
return;
for (int i = 0; i < request->params(); i++)
Serial.print("Prm:");
Serial.println(request->getParam(i)->value());
if (request->getParam(i)->name().equals(PARAM_INPUT_DEVICE_NAME))
String deviceName = request->getParam(i)->value();
if (deviceName.length() > 0 && deviceName.length() <= MAX_CONF_STRING)
strcpy(DeviceConfig.DeviceName, deviceName.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_TETHERING_PWD))
String tetPwd = request->getParam(i)->value();
if (tetPwd.length() > 0 && tetPwd.length() <= MAX_CONF_STRING)
strcpy(DeviceConfig.TetherPwd, tetPwd.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_AP_SSID))
String apSsid = request->getParam(i)->value();
if (apSsid.length() > 0 && apSsid.length() <= MAX_CONF_SSID_NAME)
strcpy(DeviceConfig.ApSSID, apSsid.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_AP_PWD))
String apPwd = request->getParam(i)->value();
if (apPwd.length() > 0 && apPwd.length() <= MAX_CONF_STRING)
strcpy(DeviceConfig.ApPwd, apPwd.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_PORTAL_USERNAME))
String pUser = request->getParam(i)->value();
if (pUser.length() > 0 && pUser.length() <= MAX_CONF_STRING)
strcpy(DeviceConfig.PortalUser, pUser.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_PORTAL_PWD))
String pPwd = request->getParam(i)->value();
if (pPwd.length() > 0 && pPwd.length() <= MAX_CONF_STRING)
strcpy(DeviceConfig.PortalPwd, pPwd.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_SENSOR_SEL))
String val = request->getParam(i)->value();
if (val.length() > 0 && val.length() <= MAX_CONF_STRING)
DeviceConfig.Device = static_cast<DeviceSelect>(val.toInt());
//mqtt
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_SERVER))
strcpy(DeviceConfig.MqttServer, val.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_PORT))
DeviceConfig.MqttPort = val.toInt();
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_USER))
strcpy(DeviceConfig.MqttUser, val.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_PWD))
strcpy(DeviceConfig.MqttPwd, val.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_PUB_TOPIC))
strcpy(DeviceConfig.MqttPub, val.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_SUB_TOPIC))
strcpy(DeviceConfig.MqttSub, val.c_str());
if (request->getParam(i)->name().equals(PARAM_INPUT_MQTT_PUB_SEC))
DeviceConfig.MqttPubSec = val.toInt();
request->redirect(WEB_PAGE_ROOT);
saveConfig();
deviceInit();
mqttInit();
if (client.connected())
client.disconnect();
server.serveStatic(WEB_PAGE_ASSETS, SPIFFS, WEB_PAGE_ASSETS);
// Start server
server.begin();
lastMsWiFiSta = millis();
mqttInit();
mqttReconnect();
Serial.println("Started...");
void deviceInit()
Serial.println("Device init...");
if (DeviceConfig.Device == DeviceSelect::DHT_11)
dht = new DHT_Unified(AIO_SENSOR_PIN_1, DHT11);
Serial.print("Using DHT...");
dht->begin();
sensor_t sensor;
dht->temperature().getSensor(&sensor);
dht->humidity().getSensor(&sensor);
else if (DeviceConfig.Device == PIR || DeviceConfig.Device == LDR /*||
DeviceConfig.Device == Sound*/)
Serial.print("Using digital sensor...");
pinMode(AIO_SENSOR_PIN_1, INPUT);
else if (DeviceConfig.Device == Relay)
Serial.print("Using relay...");
pinMode(AIO_SENSOR_PIN_1, OUTPUT);
else if (DeviceConfig.Device == Distance)
Serial.print("Using distance ensor...");
hcsr = new Simple_HCSR04(DISTANCE_ECHO_PIN, DISTANCE_TRIG_PIN);
else if (DeviceConfig.Device == SoilMoisture)
Serial.print("Using Soil Moisture sensor...");
void mqttInit()
client.setServer(DeviceConfig.MqttServer, DeviceConfig.MqttPort);
client.setCallback(mqttCallback);//fungsi yang akan diesekusi ketika mqtt mendapat data masuk
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++)
Serial.print((char)payload[i]);
Serial.println();
if (strcmp(topic, DeviceConfig.MqttSub) == 0)
Serial.print("Recvd relay command parse code: ");
StaticJsonDocument<100> doc;
DeserializationError error = deserializeJson(doc, (char *)payload);
Serial.println(error.code());
if (error == DeserializationError::Ok)
if (doc.containsKey("state") && doc["state"].is<int>())
DeviceConfig.RelayOn = (doc["state"].as<int>() == 1);
Serial.print("Changing state: ");
Serial.print(DeviceConfig.RelayOn );
Serial.println();
uint32_t lastReconnectMs = 0;
if (!client.connected() && WiFi.getMode() == WIFI_STA && WiFi.status() == WL_CONNECTED &&
millis() - lastReconnectMs > 5000)
Serial.print("Attempting MQTT connection...");
String clientId = String(DeviceConfig.DeviceName) + "-";
clientId += String(random(0xffff), HEX);
if (client.connect(clientId.c_str(), DeviceConfig.MqttUser, DeviceConfig.MqttPwd))
Serial.println("connected");
Serial.println("Subscribing " + String(DeviceConfig.MqttSub) + (client.subscribe(DeviceConfig.MqttSub) ? " OK" : " FAIL"));
else
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
lastReconnectMs = millis();
#define FIRE_THRESH 1000
DynamicJsonDocument doc(2048);
JsonObject devData = doc.createNestedObject("data");
#ifdef DUMMY_SENSOR
devData["humidity"] = "40 %";
devData["temperature"] = "33.4 celcius";
#else
if (dht == nullptr)
deviceInit();
sensors_event_t event;
dht->temperature().getEvent(&event);
if (isnan(event.temperature))
Serial.println(F("Error reading temperature!"));
devData["temperature"] = "error";
else
Serial.print(F("Temperature: "));
Serial.print(event.temperature);
Serial.println(F("°C"));
devData["temperature"] = String(event.temperature);// + " celcius";
// Get humidity event and print its value.
dht->humidity().getEvent(&event);
if (isnan(event.relative_humidity))
Serial.println(F("Error reading humidity!"));
devData["humidity"] = "error";
else
Serial.print(F("Humidity: "));
Serial.print(event.relative_humidity);
Serial.println(F("%"));
devData["humidity"] = String(event.relative_humidity) ;//+ " %";
else if (DeviceConfig.Device == DeviceSelect::PIR)
devData["detection"] = (digitalRead(AIO_SENSOR_PIN_1) == PIR_ACTIVE) ? "Motion Detected" : "No Motion Detected";
// else if (DeviceConfig.Device == DeviceSelect::SoilMoisture)
// devData["detection"] = (digitalRead(AIO_SENSOR_PIN_1) == PIR_ACTIVE ? "Dry" : "Wet");
//else if (DeviceConfig.Device == DeviceSelect::LDR)
// devData["detection"] = (digitalRead(AIO_SENSOR_PIN_1) == PIR_ACTIVE ? "High" : "Low");
devData["value"] = (analogRead(AIO_SENSOR_PIN_1));
else if(DeviceConfig.Device == DeviceSelect::SoilMoisture){
#ifdef DUMMY_SENSOR
devData["moisture"] = "32.4 ";
#else
if (soil == nullptr)
devData["moisture"] = (analogRead(AIO_SENSOR_PIN_1)); //+ " cm";
//float test = analogRead(AIO_SENSOR_PIN_1);
//devData["Moisture"] = String(test);
/*else if (DeviceConfig.Device == DeviceSelect::SoilMoisture)
#ifdef DUMMY_SENSOR
devData["moisture"] = "180";
#else
if(soil == nullptr)
deviceInit();
devData["moisture"] = String(analogRead(AIO_SENSOR_PIN_1));
else if (DeviceConfig.Device == DeviceSelect::Sound)
devData["analog_reading"] = (digitalRead(AIO_SENSOR_PIN_1) == PIR_ACTIVE ? "Sound detected" : "No Sound");
else if (DeviceConfig.Device == DeviceSelect::Distance)
#ifdef DUMMY_SENSOR
devData["distance"] = "32.4 cm";
#else
if (hcsr == nullptr)
deviceInit();
devData["distance"] = String(hcsr->measure()->cm()) + " cm";
else if (DeviceConfig.Device == DeviceSelect::Relay)
devData["state"] = (DeviceConfig.RelayOn ? "ON" : "OFF");
doc["device_type"] = DEVICE_NAME[DeviceConfig.Device - 1];
doc["local_ip"] = WiFi.localIP().toString();
String ret;
serializeJsonPretty(doc, ret);
return ret;
bool toggleHb = true;
bool staConnected = false;
uint64_t lastSendMs = 0;
void loop()
if (WiFi.getMode() == WIFI_STA && WiFi.status() != WL_CONNECTED && millis() - lastMsWiFiSta > CONNECT_STA_TIMEOUT)
Serial.print("Dropping AP mode ");
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apLocalIp, apLocalIpGateway, apLocalIpSubnet);
WiFi.softAP(DeviceConfig.DeviceName, DeviceConfig.TetherPwd);
Serial.println("OK");
else if (WiFi.getMode() == WIFI_STA && WiFi.status() == WL_CONNECTED)
if (!staConnected)
staConnected = true;
Serial.println(String("Connected to [") + WiFi.SSID() + "] IP: " + WiFi.localIP().toString());
if (millis() - lastMsHb > HB_PERIOD_MS)
lastMsHb = millis();
digitalWrite(LED_HB, !digitalRead(LED_HB));
mqttReconnect();
if (client.connected() && millis() - lastSendMs >= (DeviceConfig.MqttPubSec * 1000))
Serial.print("Publishing:");
String json = composeSensorJson();
Serial.println(json);
Serial.println(client.publish(DeviceConfig.MqttPub, json.c_str()) ? "OK" : "FAIL");
lastSendMs = millis();
if (DeviceConfig.Device == Relay) {
digitalWrite(AIO_SENSOR_PIN_1, DeviceConfig.RelayOn ? RELAY_ACTIVE : RELAY_INACTIVE);
client.loop();
