I am trying to move some files out into folders that I can share with other apps. I can’t get lib_extra_dirs to work.
I added
lib_extra_dirs = /Users/paul/Documents/PlatformIO/Projects/Madsys
to my plaformio.ini by none of the .cpp files in there get compiled.
My structure is
~Documents/PlatformIO/Projects/
| /180228-122544-teensy36
| /src
| | main.cpp
| /lib
| platform.ini
| /Madsys
| /Song
| | | Song.h
| | | Song.cpp
I added
build_flags = (…) -I/Users/Paul/Documents/PlatformIO/Projects/Madsys
and the include files work fine.
Everything builds if the Song/ folder is right next to main.cpp
-I~/Documents/PlatformIO/Projects/Madsys broke the includes BTW. This is under OSX High Sierra.
I have reviewed the documentation several times and still can’t get this to work, so any help would be appreciated. I have spend hours on this. Something is wrong or missing from the documentation.
Everything builds fine until I move
Song
| Song.h
| Song.cpp
from my src/ folder to the folder pointed to by lib_extra_dirs. Then the .cpp file is not compiled.
Here is my platform.ini before
; Redirecting...
[env:teensy36]
platform = teensy
board = teensy36
#lib_deps = USBMIDI
#build_flags = -D USB_MIDI
build_flags = -D LUA_32BITS -D HAVE_PTHREAD_H -D _POSIX_THREADS -fexceptions -I/Users/Paul/Documents/PlatformIO/Projects/Madsys
#-D LUA_USE_POSIX
-Idir ← Add the directory dir to the head of the list of directories to be searched for header files
The files are here after moving them:
xxxx$ ls /Users/paul/Documents/PlatformIO/Projects/Madsys/Song
Song.cpp Song.h
Same problem here, did you find a solution for this problem?
What’s your setup for reproduction?
