Hi, I’m using PlatformIO on Linux Mint with Arduino as a component and my project has an external arduino-esp32 dependency in lib_deps, on compile the library is installed in pio./libdeps but the compiler can’t find it;
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
Library Manager: Installing me-no-dev/ESP Async WebServer @ ^1.2.3
Library Manager: ESP Async WebServer@1.2.3 has been installed!
Library Manager: Resolving dependencies...
Library Manager: Installing AsyncTCP
Library Manager: Warning! More than one package has been found by AsyncTCP requirements:
Library Manager: - me-no-dev/AsyncTCP@1.1.1
Library Manager: - kubafilinger/AsyncTCP@1.1.1
Library Manager: - zeed/AsyncTCP@1.1.1
Library Manager: Please specify detailed REQUIREMENTS using package owner and version (shown above) to avoid name conflicts
Library Manager: AsyncTCP@1.1.1 has been installed!
PLATFORM: Espressif 32 (5.1.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 2.0.4+sha.c93bf11
- framework-espidf @ 3.40401.0 (4.4.1)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
Generating assembly for certificate bundle...
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Found 0 compatible libraries
Compiling .pio/build/esp32dev/src/main.o
Generating LD script .pio/build/esp32dev/memory.ld
Compiling .pio/build/esp32dev/app_trace/app_trace.o
Compiling .pio/build/esp32dev/app_trace/app_trace_util.o
Compiling .pio/build/esp32dev/app_trace/host_file_io.o
src/main.cpp:2:10: fatal error: ESPAsyncWebServer.h: No such file or directory
* Looking for ESPAsyncWebServer.h dependency? Check our library registry!
* CLI > platformio lib search "header:ESPAsyncWebServer.h"
* Web > https://registry.platformio.org/search?q=header:ESPAsyncWebServer.h
#include "ESPAsyncWebServer.h"
compilation terminated.
Compiling .pio/build/esp32dev/app_trace/gcov/gcov_rtio.o
*** [.pio/build/esp32dev/src/main.o] Error 1
my platform.ini file;
framework = espidf
platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.4
; set cpu frequency - 80, 160 or 240MHz
; Serial Monitor options
upload_port = /dev/tty*
upload_speed = 115200
board_build.flash_mode = dio
lib_ldf_mode = chain+
-D ESP32
me-no-dev/ESP Async WebServer@^1.2.3
and main.cpp
#include "Arduino.h"
extern "C" void app_main()
initArduino();
while(!Serial){
; // wait for serial port to connect
while(true){
Serial.println("loop");
