Hi @sivar2311
Look like it most of the error is stemming out WiFi Libary, but note that I changed everything yday as I had been trying very hard to get around the problem and ended up pulling WiFiManager code and removing Alanswx’s git reference from here. In the mean time I forgot to remove the tzapu’s WifiManager
-Jag
I have tried the minimal example of the alanswx/ESPAsyncWiFiManager on my ESP32-C3. I do not get an AP displayed either.
But a WiFi.softAP() works perfectly.
The problem seems to come from the library.
Hi @sivar2311
Thanks for confirming. Eventually I figured there might be one or other issue as I laid out below
- Alanswx’s ESPAsyncWiFimanager didn’t work for me from the library but when I include the file directly into project and not include his library I am, with the help of GitHub - mathieucarbou/ESPAsyncWebServer: Asynchronous HTTP and WebSocket Server Library for ESP32, ESP8266 and RP2040.
- Its possible that two of my ESP32c3 supermini has issues, but have to confirm by testing it out.
here is my platformIO as it sits
[env:esp32-c3-devkitm-1]
; board = esp32-c3-devkitc-02
board = esp32-c3-devkitm-1
LittleFS
; https://github.com/tzapu/WiFiManager
; https://github.com/me-no-dev/ESPAsyncWebServer
https://github.com/mathieucarbou/ESPAsyncWebServer
powerbroker2/SafeString @ ^4.1.31
bblanchon/ArduinoJson @ ^7.0.3
ayushsharma82/ElegantOTA
dlloydev/ESP32 ESP32S2 AnalogWrite@^5.0.2
; madhephaestus/ESP32Servo @ ^3.0.5
-D ARDUINO_USB_CDC_ON_BOOT=1
-D ARDUINO_USB_MODE=1
-fpermissive
-DELEGANTOTA_USE_ASYNC_WEBSERVER=1
-DESPWifiManualSetup=false
-DBOARD_HAS_PSRAM
board_build.f_cpu = 80000000L
; board_build.mcu = esp32c3
board_build.flash_mode = dio
board_build.partitions = tinyuf2-partitions-4MB.csv
monitor_speed = 115200```
