Just updated the VSCode and PIO including all platforms. Now I have the issue that the debugger won’t start I get the following:
Reading symbols from c:\Users\Niels\Documents\PlatformIO\Projects\nanoBrewer.pio\build\nodemcu-32s\firmware.elf…
done.
PlatformIO: debug_tool = olimex-arm-usb-ocd-h
Open On-Chip Debugger v0.10.0-esp32-20210721 (2021-07-21-13:35)
Licensed under GNU GPL v2
For bug reports, read
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 500 kHzInfo : tcl server disabled
Info : telnet server disabled
Info : clock speed 500 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : accepting ‘gdb’ connection from pipe
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x00000000, debug_reason=00000000
Info : Set GDB target to ‘esp32.cpu0’
Info : Flash mapping 0: 0x3ffc089c → 0x3ffc089c, 1048322 KB
Info : Flash mapping 1: 0x3ffc089c → 0x3ffc089c, 1048322 KB
Info : Flash mapping 2: 0x0 → 0x514, 41279 KB
Info : Flash mapping 3: 0x9 → 0x6, 9790 KB
Info : Flash mapping 4: 0x1 → 0x0, 0 KB
Info : Flash mapping 5: 0x0 → 0x40091d24, 0 KB
Info : Flash mapping 6: 0x0 → 0x0, 0 KB
Info : Flash mapping 7: 0x0 → 0x400928c4, 0 KB
Info : Flash mapping 8: 0x0 → 0x0, 1048322 KB
Info : Flash mapping 9: 0x0 → 0x283bac0, 0 KB
Info : Flash mapping 10: 0x5 → 0x0, 0 KB
Info : Flash mapping 11: 0x2828b28 → 0x0, 0 KB
Info : Flash mapping 12: 0x0 → 0x0, 0 KB
Info : Flash mapping 13: 0x40091d24 → 0x5c, 0 KB
Info : Flash mapping 14: 0x0 → 0x0, 0 KB
Info : Flash mapping 15: 0x0 → 0x0, 6990 KB
Info : Flash mapping 16: 0x233cfcc6 → 0xfffffffe, 0 KB
Info : Flash mapping 17: 0x2830290 → 0x2827ff8, 41121 KB
Info : Flash mapping 18: 0x98fcac → 0x42e989, 41152 KB
Info : Flash mapping 19: 0x13 → 0xac6e18, 41331 KB
Info : Flash mapping 20: 0x2827ff8 → 0x28285b0, 0 KB
Info : Flash mapping 21: 0x98fca8 → 0x280f420, 0 KB
Info : Flash mapping 22: 0x98ffcc → 0x2b, 41119 KB
Info : Flash mapping 23: 0x28285b0 → 0x0, 4438 KB
Info : Flash mapping 24: 0x0 → 0x98fcac, 41121 KB
Info : Flash mapping 25: 0x2817be0 → 0x1c, 0 KB
Info : Flash mapping 26: 0x98fca8 → 0x2, 9791 KB
Info : Flash mapping 27: 0x0 → 0x98ffcc, 1961267 KB
Info : Flash mapping 28: 0x233cfbce → 0xfffffffe, 0 KB
Info : Flash mapping 29: 0x2830290 → 0x283eb80, 6513 KB
Info : Flash mapping 30: 0x98fce4 → 0x2817be0, 41121 KB
Info : Flash mapping 31: 0x98fd2c → 0x0, 4462 KB
Info : Flash mapping 32: 0x28285b0 → 0x65c45f, 0 KB
Info : Flash mapping 33: 0x65c884 → 0x65c6e0, 41201 KB
Info : Flash mapping 34: 0x77c0627f → 0x24, 0 KB
Info : Flash mapping 35: 0x65dda6 → 0xac0000, 16448 KB
Info : Flash mapping 36: 0xac0000 → 0x27f8e40, 0 KB
Info : Flash mapping 37: 0x0 → 0x1, 0 KB
Info : Flash mapping 38: 0x9e07d0 → 0x64, 0 KB
Info : Flash mapping 39: 0x10 → 0x9e01c4, 0 KB
Info : Flash mapping 40: 0x0 → 0xe9, 0 KB
Info : Flash mapping 41: 0xea0069 → 0x283b9f8, 41202 KB
Info : Flash mapping 42: 0x2827250 → 0xac0000, 0 KB
Info : Flash mapping 43: 0x98f9ec → 0x77c03c16, 0 KB
Info : Flash mapping 44: 0x0 → 0x0, 0 KB
Info : Flash mapping 45: 0x283c8d0 → 0x5, 9790 KB
Info : Flash mapping 46: 0x77b37379 → 0xac0000, 0 KB
Info : Flash mapping 47: 0x5f0a87 → 0x65df3e, 41201 KB
Info : Flash mapping 48: 0x283c8d0 → 0x1, 0 KB
Info : Flash mapping 49: 0x1 → 0xac6f14, 6090 KB
Info : Flash mapping 50: 0xac6e40 → 0x65df3e, 41201 KB
Info : Flash mapping 51: 0x77b4ccc0 → 0x1, 11035 KB
Info : Flash mapping 52: 0x281bb48 → 0x5f595c, 11035 KB
Info : Flash mapping 53: 0x65df3e → 0x5, 41202 KB
Info : Flash mapping 54: 0x1 → 0xac6e18, 41070 KB
Info : Flash mapping 55: 0x46282e → 0xac6e40, 6519 KB
Info : Flash mapping 56: 0x0 → 0x65e344, 6519 KB
Info : Flash mapping 57: 0x65ddf1 → 0x28051a0, 0 KB
Info : Flash mapping 58: 0x0 → 0xb1, 11035 KB
Info : Flash mapping 59: 0x283c8d0 → 0xac6e40, 41202 KB
Info : Flash mapping 60: 0xac6e18 → 0x281f9b0, 41089 KB
Info : Flash mapping 61: 0x20 → 0x65c7b2, 41053 KB
Info : Flash mapping 62: 0x660000 → 0xac6e18, 0 KB
Info : Flash mapping 63: 0x10 → 0x98fea8, 4102 KB
Info : Flash mapping 64: 0xac6e18 → 0x63920d, 11034 KB
Info : Flash mapping 65: 0x639214 → 0x6391cc, 1961617 KB
Info : Flash mapping 66: 0x0 → 0x0, 9791 KB
Info : Flash mapping 67: 0x77c05dde → 0x98ffcc, 0 KB
Info : Flash mapping 68: 0xac6be8 → 0x10, 9791 KB
Info : Flash mapping 69: 0x62aa50 → 0xd, 11034 KB
Info : Flash mapping 70: 0x4 → 0x0, 11034 KB
Info : Flash mapping 71: 0x10 → 0x98ff70, 4100 KB
Info : Flash mapping 72: 0xd → 0xac6be8, 11022 KB
Info : Flash mapping 73: 0x77c1bd9b → 0x1c10, 4205 KB
Info : Flash mapping 74: 0x54f7764c → 0x0, 3355443 KB
Info : Flash mapping 75: 0xcccccccc → 0xcccccccc, 3355443 KB
Info : Flash mapping 76: 0xcccccccc → 0xcccccccc, 3355443 KB
Info : Flash mapping 77: 0xcccccccc → 0xffffffff, 0 KB
Info : Flash mapping 78: 0x546c6148 → 0x38, 0 KB
Info : Flash mapping 79: 0xac6be8 → 0xbee, 10202 KB
Info : Flash mapping 80: 0xcf79c8 → 0x0, 0 KB
Info : Flash mapping 81: 0x0 → 0x0, 0 KB
Info : Flash mapping 82: 0x0 → 0x0, 0 KB
Info : Flash mapping 83: 0x0 → 0x0, 0 KB
Info : Flash mapping 84: 0x0 → 0x0, 0 KB
Info : Flash mapping 85: 0x0 → 0x0, 0 KB
Info : Flash mapping 86: 0x4014e0 → 0x4014e0, 9791 KB
Info : Flash mapping 87: 0x2cd000 → 0x4014e0, 4101 KB
Info : Flash mapping 88: 0x98ff80 → 0x7737fa29, 2868 KB
Info : Flash mapping 89: 0x7737fa10 → 0x98ffdc, 1962142 KB
Info : Flash mapping 90: 0x2cd000 → 0x545665a1, 0 KB
Info : Flash mapping 91: 0x0 → 0x2cd000, 0 KB
Info : Flash mapping 92: 0x0 → 0x0, 0 KB
Info : Flash mapping 93: 0x0 → 0x0, 0 KB
Info : Flash mapping 94: 0x0 → 0x0, 0 KB
Info : Flash mapping 95: 0x98ff8c → 0x0, 9791 KB
Info : Flash mapping 96: 0x77c3ad40 → 0x2302521d, 0 KB
Info : Flash mapping 97: 0x98ffec → 0x77c27a6e, 4194303 KB
Info : Flash mapping 98: 0x77c48a39 → 0x0, 0 KB
Info : Flash mapping 99: 0x4014e0 → 0x2cd000, 0 KB
Remote communication error. Target disconnected.: Success.
I also get a Visual Studio Code dialog popup stating:
Failed to launch GDB: .pioinit:11: Error in sourced command file:
Remote communication error. Target disconnected.: Success. (from interpreter-exec console
“source .pioinit”)
So, what does “.pioinit:11: Error in sourced command file:” mean??
