I’m working on a project that requires the use of the twai.h header which is located in the “driver” folder as part of the ESP32 IDF. I can see that I do have this file as part of my esp-idf framework in my .platformio/packages/framework-espidf/components/driver
. However when I try to include it in my code with #include "driver/twai.h"
when i try to build i get
fatal error: driver/twai.h: No such file or directory
5 | #include "driver/twai.h"
I’ve googled around a bunch and I’m unable to figure out why this is.
Looking at the esp-idf documentation, it mentions that you need to do the following to your CMakeLists.txt file:
I tried adding that line to my CMakeLists.txt for my CAN component like so:
REQUIRES driver
idf_component_register(SRCS "CAN.cpp"
INCLUDE_DIRS ".")
But this causes the following error:
CMake Error at components/CAN/CMakeLists.txt:1:
Parse error. Expected "(", got identifier with text "driver".
If anyone knows how to fix this for including things from the driver folder, the help would be greatly appreciated.
