I have a different project that is not working as expected so I thought I would try a simple debug session first to confirm that debugging was working. I have a custom board based on the STM32F405RG and am connected to a Win10 PC using a ST-Link clone flashed with the latest ST firmware. I can successfully program the board using SWD. I am using VS Code w/ PIO. The code is simple:
#define myPin PB11
pinMode(myPin, OUTPUT);
//Serial.begin(115200);
//Serial4.println("Hello World");
digitalWrite(myPin, HIGH); // <--Breakpoint set here
delay(50);
digitalWrite(myPin, LOW);
delay(100);
When I go to debug the session starts and then it opens the startup_stm32f405xx.s file. It initially pauses but then loads the debug toolbar but it starts immediately running and I don’t have the option to single step, just pause and stop. If I pause I end up in the startup file on line 127 which is an infinite loop statement:
* @brief This is the code that gets called when the processor receives an
* unexpected interrupt. This simply enters an infinite loop, preserving
* the system state for examination by a debugger.
* @param None
* @retval None
.section .text.Default_Handler,"ax",%progbits
Default_Handler:
Infinite_Loop:
b Infinite_Loop
.size Default_Handler, .-Default_Handler
If I try any of the step commands it just continues and I have to pause again. I have set a breakpoint in the loop() routine on a digitalwrite command and I see the red dot as well as it being listed on the left side of the window. I’ve searched and haven’t found anything special I’m supposed to do so I’m a bit stumped why the debug session isn’t just starting and stopping at the first breakpoint. I would also expect that I should have to hit run first but that doesn’t happen either it just immediately starts running.
Here is what is in the debug console.
Processing stm32test (platform: ststm32; board: IOTech_STM32F405; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/IOTech_STM32F405.html
PLATFORM: ST STM32 5.7.0 > IOTech Villara Tester
HARDWARE: STM32F405RGT6 168MHz, 192KB RAM, 1MB Flash
DEBUG: Current (stlink) External (stlink)
PACKAGES: framework-arduinoststm32 3.10700.191028 (1.7.0), toolchain-gccarmnoneeabi 1.70201.0 (7.2.1)
Found 10 compatible libraries
Building in debug mode
Checking size .pio\build\stm32test\firmware.elf
DATA: [ ] 0.5% (used 948 bytes from 196608 bytes)
PROGRAM: [ ] 1.5% (used 16032 bytes from 1048576 bytes)
========================= [SUCCESS] Took 2.60 seconds =========================
Reading symbols from c:\Users\george\OneDrive\Documents\PlatformIO\Projects\Just_a_Test\.pio\build\stm32test\firmware.elf...
done.
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-11:28)
Licensed under GNU GPL v2
For bug reports, read
hla_swd
none separate
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 2000 kHz
Info : STLINK V2J34S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 2.451600
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x61000003 pc: 0x08002fb8 msp: 0x2002ffd0
Info : device id = 0x10076413
Info : flash size = 1024 kbytes
Info : flash size = 512 bytes
WWDG_IRQHandler () at C:\Users\george\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F4xx\Source\Templates\gcc\startup_stm32f405xx.s:127
127 b Infinite_Loop
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
xPSR: 0x01000000 pc: 0x08002f68 msp: 0x20030000
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1012). Workaround: increase "set remotetimeout" in GDB
Loading section .isr_vector, size 0x188 lma 0x8000000
Loading section .text, size 0x3820 lma 0x8000188
Loading section .rodata, size 0x5e8 lma 0x80039a8
Loading section .ARM, size 0x8 lma 0x8003f90
Loading section .init_array, size 0x14 lma 0x8003f98
Loading section .fini_array, size 0x8 lma 0x8003fac
Loading section .data, size 0x98 lma 0x8003fb4
Start address 0x8002f68, load size 16460
Transfer rate: 7 KB/sec, 2351 bytes/write.
Temporary breakpoint 1 at 0x8000c9e: file C:\Users\george\.platformio\packages\framework-arduinoststm32\cores\arduino\main.cpp, line 56.
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
