I am using Visual Studio Code with the official PlatformIO extensions.
I can successfully Build and Upload to my Seeduino (seeedstudio.com/Seeeduino-V4.2-p-2517.html).
But, I cannot debug my Seeeduino board. Error in the DEBUG CONSOLE in the IDE is:
undefinedError: Currently, PlatformIO does not support debugging for
seeeduino
Please mail contact@pioplus.com or visit Redirecting...
So, the link Debugging — PlatformIO latest documentation states (Note Seeeduino absence):
ID Name Platform Debug Microcontroller Frequency Flash RAM
seeedArchBLE Seeed Arch BLE Nordic nRF51 CMSIS-DAP (on-board) NRF51822 16 MHz 128 Kb 16 Kb
seeedArchLink Seeed Arch Link Nordic nRF51 CMSIS-DAP (on-board) NRF51822 16 MHz 256 Kb 16 Kb
seeedArchMax Seeed Arch Max ST STM32 Black Magic Probe, ST-LINK/V2-1 (on-board) STM32F407VET6 168 MHz 512 Kb 192 Kb
seeedArchPro Seeed Arch Pro NXP LPC CMSIS-DAP (on-board) LPC1768 96 MHz 512 Kb 64 Kb
seeedTinyBLE Seeed Tiny BLE Nordic nRF51 CMSIS-DAP (on-board)
Whereas the board is officially supported:
Atmel AVR — PlatformIO latest documentation but clearly shows no Debug support.
seeeduino Seeeduino Atmel AVR ATMEGA328P 16 MHz 32 Kb 2 Kb
==========PROJECT DETAILS=============
[PLATFORMIO INI]
platformio.ini contains:
[platformio]
env_default = seeeduino
[env:uno]
board = uno
[env:seeeduino]
board = seeeduino
I get exactly the same results (shown below in detail) if I specify env_default=uno
How to proceed ?
For those interested in my environment and project details …
==========INSTALLATION DETAILS=============
Environment:
Distributor ID: Ubuntu
Description: Ubuntu 16.04.3 LTS
Release: 16.04
Codename: xenial
Platformio Version:
platformio --version
PlatformIO, version 3.5.0
I added my user to the dialout group:
sudo usermod -a -G dialout my_username
so that I have access to the /dev/ttyACM* (* = 1 or 2 typically)
==========UDEV RULES=============
I previously had 98-openocd-udev.rules, but removed this when I added 99-platformio-udev.rules
99 rules installed as per:
sudo cp 99-platformio-udev.rules /etc/udev/rules.d/99-platformio-udev.rules
[Platformio Upload Task excutes successfully with warning:]
Warning! Please install `99-platformio-udev.rules` and check that your board's PID and VID are listed in the rules.
https://raw.githubusercontent.com/platformio/platformio/develop/scripts/99-platformio-udev.rules
Auto-detected: /dev/ttyACM1
Uploading .pioenvs/seeeduino/firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pioenvs/seeeduino/firmware.hex"
avrdude: writing flash (9576 bytes):
Writing | ################################################## | 100% 1.54s
avrdude: 9576 bytes of flash written
avrdude: verifying flash memory against .pioenvs/seeeduino/firmware.hex:
avrdude: load data flash data from input file .pioenvs/seeeduino/firmware.hex:
avrdude: input file .pioenvs/seeeduino/firmware.hex contains 9576 bytes
Reading | ################################################## | 100% 1.23s
avrdude: verifying ...
avrdude: 9576 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
========================================================================= [SUCCESS] Took 5.00 seconds =========================================================================
================================================================================== [SUMMARY] ==================================================================================
Environment uno [SKIP]
Environment nodemcu [SKIP]
Environment teensy31 [SKIP]
Environment lpmsp430g2553 [SKIP]
Environment seeeduino [SUCCESS]
