I just updated to v3.5.1 (using Visual Studio Code). Since, I cannot compile my STM32Cube project.
I tried with the Blink example and same issue:
Executing task: platformio.exe run <
[01/03/18 15:04:41] Processing nucleo_f072rb (platform: ststm32; build_flags: -DF0; board: nucleo_f072rb; framework: stm32cube)
File “c:.platformio\penv\lib\site-packages\platformio_main_.py”, line 120, in main
cli(None, None, None)
File “c:.platformio\penv\lib\site-packages\click\core.py”, line 700, in call
File “c:.platformio\penv\lib\site-packages\click\core.py”, line 680, in main
rv = self.invoke(ctx)
File “c:.platformio\penv\lib\site-packages\click\core.py”, line 1027, in invoke
File “c:.platformio\penv\lib\site-packages\click\core.py”, line 873, in invoke
File “c:.platformio\penv\lib\site-packages\click\core.py”, line 508, in invoke
return callback(*args, **kwargs)
File “c:.platformio\penv\lib\site-packages\click\decorators.py”, line 16, in new_func
File “c:.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 109, in cli
result = (envname, ep.process())
File “c:.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 194, in process
result = self._run()
File “c:.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 296, in _run
return p.run(build_vars, build_targets, self.silent, self.verbose)
File “c:.platformio\penv\lib\site-packages\platformio\managers\platform.py”, line 358, in run
variables[‘build_script’] = self.get_build_script()
File “c:.platformio\penv\lib\site-packages\platformio\managers\platform.py”, line 525, in get_build_script
raise NotImplementedError()
NotImplementedError
- Verify that you have the latest version of PlatformIO using
pip install -U platformio
command
- Try to find answer in FAQ Troubleshooting section
Redirecting...
- Report this problem to the developers
Issues · platformio/platformio-core · GitHub
Any idea?
Thanks,
Aurelien
