I’m trying to compile a simple “hello world” sketch for the u8g2 library and am running into odd compiler errors.
The whole sketch
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, A5, A4);
// End of constructor list
void setup(void) {
u8g2.begin();
void loop(void) {
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_ncenB08_tr); // choose a suitable font
u8g2.drawStr(0,10,"Hello World!"); // write something to the internal memory
u8g2.sendBuffer(); // transfer internal memory to the display
delay(1000);
platformio.ini
[env:ATmega328P]
board = ATmega328P
olikraus/U8g2@^2.34.22
The errors are numerous, but all about undefined references:
Processing ATmega328P (platform: atmelavr; board: ATmega328P; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega328P.html
PLATFORM: Atmel AVR (4.2.0) > ATmega328P/PA
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 32KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr-minicore @ 2.2.2
Found 9 compatible libraries
|-- U8g2 @ 2.35.7
|-- SPI @ 1.0
|-- Wire @ 1.1
Archiving .pio/build/ATmega328P/lib89f/libSPI.a
Indexing .pio/build/ATmega328P/lib89f/libSPI.a
Archiving .pio/build/ATmega328P/lib658/libWire.a
Compiling .pio/build/ATmega328P/lib72f/Wire1/Wire1.cpp.o
Compiling .pio/build/ATmega328P/lib72f/Wire1/utility/twi1.c.o
Indexing .pio/build/ATmega328P/lib658/libWire.a
Compiling .pio/build/ATmega328P/libbc1/U8g2/clib/mui.c.o
Compiling .pio/build/ATmega328P/libbc1/U8g2/clib/mui_u8g2.c.o
Compiling .pio/build/ATmega328P/libbc1/U8g2/clib/u8g2_bitmap.c.o
Compiling .pio/build/ATmega328P/libbc1/U8g2/clib/u8g2_box.c.o
Compiling .pio/build/ATmega328P/libbc1/U8g2/clib/u8g2_buffer.c.o
Compiling .pio/build/ATmega328P/libbc1/U8g2/clib/u8g2_button.c.o
/Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c: In function 'twi_init1':
/Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c:89:16: error: 'SDA1' undeclared (first use in this function); did you mean 'SDA'?
digitalWrite(SDA1, 1);
SDA
/Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c:89:16: note: each undeclared identifier is reported only once for each function it appears in
/Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c:90:16: error: 'SCL1' undeclared (first use in this function); did you mean 'SCL'?
digitalWrite(SCL1, 1);
SCL
In file included from /Users/davidarthur/.platformio/packages/toolchain-atmelavr/avr/include/avr/io.h:99:0,
from /Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c:26:
/Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c:93:7: error: 'TWSR1' undeclared (first use in this function); did you mean 'TWSR'?
cbi(TWSR1, TWPS0);
/Users/davidarthur/.platformio/packages/framework-arduino-avr-minicore/libraries/Wire1/src/utility/twi1.c:93:3: note: in expansion of macro 'cbi'
cbi(TWSR1, TWPS0);
*** [.pio/build/ATmega328P/lib72f/Wire1/Wire1.cpp.o] Error 1
Works fine in Arduino IDE.
