I am looking for a board supported by platformio among esp32 development boards with touch LCD. I found esp-wrover-kit, but it’s discontinued.
So, I am reviewing another board with the following specifications, can this board be supported?
https://www.makerfabs.com/wiki/index.php?title=ESP32_TFT_LCD_with_Camera(3.5'')
- Integrated ESP32 Wrover 2.4G WiFi and Bluetooth
- Wi-Fi Protocols: 802.11b/g/n(802.11n up to 150Mbps),A-MPDU and A-MSDU aggregation and 0.4us guard interval support
- Wi-Fi Frequency range: 2.402GHz - 2.483Ghz
- Bluetooth Protocols: Bluetooth v4.2 BR/EDR and BLE specification
- Bluetooth Radio: NZIF receiver with-97 dBm sensitivity, Class-1/class-2 and class-3 transmitter, AFH
- Bluetooth Audio: CVSD and SBC
- Arduino Compatible: You can play it with Arduino IDE
- OV2640: A 1/4inch CMOS UXGA (1632*1232) image sensor manufactured by OmniVision
- OV2640 supports output images up to 2 million pixels
- LCD 3.5 inch Amorphous-TFT-LCD (Thin Film Transistor Liquid Crystal Display) for mobile-phone or handy electrical equipment
- LCD Driver: ILI9488
- LCD Resolution: 320*480
- NS2009: A 4-wire resistive touch screen control circuit with I2C interface, which contains A 12-bit resolution A/D converter
- FT6236 Series ICs are single-chip capacitive touch panel controller IC with a built-in 16 bit enhanced Micro-controller unit (MCU)
- Power supply: 5V, Type-C USB
- Micro SD card slot on the board
- Board size: 66mm * 85mm
