Archiving .pio\build\esp01_1m\libFrameworkArduino.a
Linking .pio\build\esp01_1m\firmware.elf
Retrieving maximum program size .pio\build\esp01_1m\firmware.elf
Checking size .pio\build\esp01_1m\firmware.elf
RAM: [=== ] 34.2% (used 27980 bytes from 81920 bytes)
Flash: [=== ] 34.2% (used 260893 bytes from 761840 bytes)
Building .pio\build\esp01_1m\firmware.bin
Creating BIN file “.pio\build\esp01_1m\firmware.bin” using “C:\Users\DHAKA.platformio\packages\framework-arduinoespressif8266\bootloaders\eboot\eboot.elf” and “.pio\build\esp01_1m\firmware.elf”
Configuring upload protocol…
AVAILABLE: espota, esptool
Looking for upload port…
Auto-detected: COM4
Uploading .pio\build\esp01_1m\firmware.bin
esptool.py v3.1
Serial port COM4
WARNING: Pre-connection option “no_reset” was selected. Connection may fail if the chip is not in bootloader or flasher stub mode.
Connecting…
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 84:f3:eb:58:ac:99
Uploading stub…
Running stub…
Stub running…
Configuring flash size…
Flash will be erased from 0x00000000 to 0x00040fff…
Compressed 265040 bytes to 195054…
Writing at 0x00000000… (8 %)
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 4582, in
_main()
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 4575, in _main
main()
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 4122, in main
operation_func(esp, args)
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 3424, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 149, in inner
return func(*args, **kwargs)
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 874, in flash_defl_block
self.check_command(“write compressed data to flash after seq %d” % seq,
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 462, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 425, in command
self.write(pkt)
File “C:\Users\DHAKA.platformio\packages\tool-esptoolpy\esptool.py”, line 388, in write
self._port.write(buf)
File “C:\Users\DHAKA.platformio\penv\lib\site-packages\serial\serialwin32.py”, line 325, in write
raise SerialTimeoutException(‘Write timeout’)
serial.serialutil.SerialTimeoutException: Write timeout
*** [upload] Error 1
