Can not initialize Project for Espressif IoT Dev framework
Thanks a lot !
Processing featheresp32 (platform: espressif32; board: featheresp32; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32.html
PLATFORM: Espressif 32 (3.1.0) > Adafruit ESP32 Feather
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-espidf 3.40200.210118 (4.2.0)
 - tool-cmake 3.16.4
 - tool-esptoolpy 1.30000.201119 (3.0.0)
 - tool-ninja 1.7.1
 - toolchain-esp32ulp 1.22851.191205 (2.28.51)
 - toolchain-xtensa32 2.80400.210211 (8.4.0)
Reading CMake configuration...
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
-- App "a" version: 1
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script /home/kh/pio-projects/a/.pio/build/featheresp32/esp-idf/esp32/esp32_out.ld
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp32/ld/esp32.project.ld.in
-- Adding linker script /home/kh/.platformio/packages/framework-espidf/components/esp32/ld/esp32.peripherals.ld
-- Components: __pio_env app_trace app_update asio bootloader bootloader_support bt cbor coap console cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_ipc esp_local_ctrl esp_netif esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos heap idf_test jsmn json libsodium log lwip mbedtls mdns mqtt newlib nghttp nvs_flash openssl partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs src tcp_transport tcpip_adapter tinyusb ulp unity vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: /home/kh/pio-projects/a/.pio/build/featheresp32/__pio_env /home/kh/.platformio/packages/framework-espidf/components/app_trace /home/kh/.platformio/packages/framework-espidf/components/app_update /home/kh/.platformio/packages/framework-espidf/components/asio /home/kh/.platformio/packages/framework-espidf/components/bootloader /home/kh/.platformio/packages/framework-espidf/components/bootloader_support /home/kh/.platformio/packages/framework-espidf/components/bt /home/kh/.platformio/packages/framework-espidf/components/cbor /home/kh/.platformio/packages/framework-espidf/components/coap /home/kh/.platformio/packages/framework-espidf/components/console /home/kh/.platformio/packages/framework-espidf/components/cxx /home/kh/.platformio/packages/framework-espidf/components/driver /home/kh/.platformio/packages/framework-espidf/components/efuse /home/kh/.platformio/packages/framework-espidf/components/esp-tls /home/kh/.platformio/packages/framework-espidf/components/esp32 /home/kh/.platformio/packages/framework-espidf/components/esp_adc_cal /home/kh/.platformio/packages/framework-espidf/components/esp_common /home/kh/.platformio/packages/framework-espidf/components/esp_eth /home/kh/.platformio/packages/framework-espidf/components/esp_event /home/kh/.platformio/packages/framework-espidf/components/esp_gdbstub /home/kh/.platformio/packages/framework-espidf/components/esp_hid /home/kh/.platformio/packages/framework-espidf/components/esp_http_client /home/kh/.platformio/packages/framework-espidf/components/esp_http_server /home/kh/.platformio/packages/framework-espidf/components/esp_https_ota /home/kh/.platformio/packages/framework-espidf/components/esp_https_server /home/kh/.platformio/packages/framework-espidf/components/esp_ipc /home/kh/.platformio/packages/framework-espidf/components/esp_local_ctrl /home/kh/.platformio/packages/framework-espidf/components/esp_netif /home/kh/.platformio/packages/framework-espidf/components/esp_ringbuf /home/kh/.platformio/packages/framework-espidf/components/esp_rom /home/kh/.platformio/packages/framework-espidf/components/esp_serial_slave_link /home/kh/.platformio/packages/framework-espidf/components/esp_system /home/kh/.platformio/packages/framework-espidf/components/esp_timer /home/kh/.platformio/packages/framework-espidf/components/esp_websocket_client /home/kh/.platformio/packages/framework-espidf/components/esp_wifi /home/kh/.platformio/packages/framework-espidf/components/espcoredump /home/kh/.platformio/packages/framework-espidf/components/esptool_py /home/kh/.platformio/packages/framework-espidf/components/expat /home/kh/.platformio/packages/framework-espidf/components/fatfs /home/kh/.platformio/packages/framework-espidf/components/freemodbus /home/kh/.platformio/packages/framework-espidf/components/freertos /home/kh/.platformio/packages/framework-espidf/components/heap /home/kh/.platformio/packages/framework-espidf/components/idf_test /home/kh/.platformio/packages/framework-espidf/components/jsmn /home/kh/.platformio/packages/framework-espidf/components/json /home/kh/.platformio/packages/framework-espidf/components/libsodium /home/kh/.platformio/packages/framework-espidf/components/log /home/kh/.platformio/packages/framework-espidf/components/lwip /home/kh/.platformio/packages/framework-espidf/components/mbedtls /home/kh/.platformio/packages/framework-espidf/components/mdns /home/kh/.platformio/packages/framework-espidf/components/mqtt /home/kh/.platformio/packages/framework-espidf/components/newlib /home/kh/.platformio/packages/framework-espidf/components/nghttp /home/kh/.platformio/packages/framework-espidf/components/nvs_flash /home/kh/.platformio/packages/framework-espidf/components/openssl /home/kh/.platformio/packages/framework-espidf/components/partition_table /home/kh/.platformio/packages/framework-espidf/components/perfmon /home/kh/.platformio/packages/framework-espidf/components/protobuf-c /home/kh/.platformio/packages/framework-espidf/components/protocomm /home/kh/.platformio/packages/framework-espidf/components/pthread /home/kh/.platformio/packages/framework-espidf/components/sdmmc /home/kh/.platformio/packages/framework-espidf/components/soc /home/kh/.platformio/packages/framework-espidf/components/spi_flash /home/kh/.platformio/packages/framework-espidf/components/spiffs /home/kh/pio-projects/a/src /home/kh/.platformio/packages/framework-espidf/components/tcp_transport /home/kh/.platformio/packages/framework-espidf/components/tcpip_adapter /home/kh/.platformio/packages/framework-espidf/components/tinyusb /home/kh/.platformio/packages/framework-espidf/components/ulp /home/kh/.platformio/packages/framework-espidf/components/unity /home/kh/.platformio/packages/framework-espidf/components/vfs /home/kh/.platformio/packages/framework-espidf/components/wear_levelling /home/kh/.platformio/packages/framework-espidf/components/wifi_provisioning /home/kh/.platformio/packages/framework-espidf/components/wpa_supplicant /home/kh/.platformio/packages/framework-espidf/components/xtensa
-- Configuring incomplete, errors occurred!
See also "/home/kh/pio-projects/a/.pio/build/featheresp32/CMakeFiles/CMakeOutput.log".
fatal: Kein Git-Repository (oder irgendein Elternverzeichnis bis zum Einhängepunkt /)
Stoppe bei Dateisystemgrenze (GIT_DISCOVERY_ACROSS_FILESYSTEM nicht gesetzt).
CMake Error at .pio/build/featheresp32/CMakeFiles/git-data/grabRef.cmake:48 (file):
  file failed to open for reading (No such file or directory):
    /home/kh/pio-projects/a/.pio/build/featheresp32/CMakeFiles/git-data/head-ref
Call Stack (most recent call first):
  /home/kh/.platformio/packages/framework-espidf/tools/cmake/third_party/GetGitRevisionDescription.cmake:80 (include)
  /home/kh/.platformio/packages/framework-espidf/tools/cmake/third_party/GetGitRevisionDescription.cmake:90 (get_git_head_revision)
  /home/kh/.platformio/packages/framework-espidf/tools/cmake/project.cmake:48 (git_describe)
  /home/kh/.platformio/packages/framework-espidf/tools/cmake/project.cmake:391 (__project_get_revision)
  CMakeLists.txt:3 (project)
