I have been trying to add the firmware to a skr v1.3. I keep getting the same error message referring to removing the .pioenvs directory and finding the Uglib file and directory. The Uglib file is in the libraries. Here are the error messages if someone could please give me a hand.
Thanks
Peter
> Executing task: C:\Users\Peter\.platformio\penv\Scripts\platformio.exe run --target upload <
Can not remove temporary directory `I:\Downloads 3D\MP Lower Rider\Firmware\mpcnc lowrider 2 - marlin 2.0 and mks tft firmware\marlin 2.0 - mpcnc lowrider2 - skr v1.3 tmc5160\.pioenvs`. Please remove it manually to avoid build issues
Processing LPC1768 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/master.zip; framework: arduino; board: nxp_lpc1768)
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1768.html
PLATFORM: NXP Arduino LPC176x 0.1.0 > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
- framework-arduino-lpc176x 0.1.3
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Converting Marlin.ino
LDF Modes: Finder ~ off, Compatibility ~ strict
LibraryManager: Installing U8glib-HAL
Using cache: C:\Users\Peter\.platformio\.cache\cf\a54ce8ed1b234ada291ce966617e3dcf
Unpacking...
FileNotFoundError: [Errno 2] No such file or directory: 'I:\\Downloads 3D\\MP Lower Rider\\Firmware\\mpcnc lowrider 2 - marlin 2.0 and mks tft firmware\\marlin 2.0 - mpcnc lowrider2 - skr v1.3 tmc5160\\.piolibdeps\\LPC1768\\_tmp_installing-einmvifz-package\\U8glib-HAL-dev\\src\\clib\\HAL_example_files\\HAL_LCD_I2C_routines.c.example':
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 156:
File "C:\Users\Peter\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 597:
File "C:\Users\Peter\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 286:
File "C:\Users\Peter\.platformio\platforms\nxplpc-arduino-lpc176x\builder\main.py", line 148:
File "C:\Users\Peter\.platformio\packages\tool-scons\script\..\engine\SCons\Environment.py", line 219:
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 131:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1036:
project.install_dependencies()
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 868:
lm.install(uri)
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\managers\lib.py", line 281:
force=force,
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\managers\package.py", line 698:
pkg_dir = self._install_from_url(name, url, requirements, track=True)
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\managers\package.py", line 482:
self.unpack(dlpath, tmp_dir)
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\managers\package.py", line 222:
return fu.unpack(dest_dir, with_progress=False)
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\unpacker.py", line 149:
self._unpacker.extract_item(item, dest_dir)
File "C:\Users\Peter\.platformio\penv\lib\site-packages\platformio\unpacker.py", line 39:
self._afo.extract(item, dest_dir)
File "C:\Users\Peter\.platformio\python37\lib\zipfile.py", line 1602:
return self._extract_member(member, path, pwd)
File "C:\Users\Peter\.platformio\python37\lib\zipfile.py", line 1673:
open(targetpath, "wb") as target:
===================================================================================== [FAILED] Took 1.02 seconds =====================================================================================
Environment Status Duration
megaatmega2560 IGNORED
megaatmega1280 IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 FAILED 00:00:01.021
LPC1769 IGNORED
melzi IGNORED
melzi_optiboot IGNORED
rambo IGNORED
sanguino_atmega644p IGNORED
sanguino_atmega1284p IGNORED
STM32F1 IGNORED
STM32F4 IGNORED
ARMED IGNORED
mks_robin IGNORED
black_stm32f407ve IGNORED
teensy35 IGNORED
malyanm200 IGNORED
esp32 IGNORED
fysetc_f6_13 IGNORED
linux_native IGNORED
================================================================================ 1 failed, 0 succeeded in 00:00:01.021 ================================================================================
