I have problem with platform, before this issue i can compile mbed source well, but i don’t know since when, it suddenly getting error. First i taught it maybe cause by the VSCode, and then i try in Atom but same error then i use PIO CLI to compile the project MBED, but still get same error. Here is the error i got:
Processing bluepill_f103c8 (platform: ststm32; board: bluepill_f103c8; framework: mbed)
Verbose mode can be enabled via
-v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 6.0.0 > BluePill F103C8
HARDWARE: STM32F103C8T6 72MHz, 20KB RAM, 64KB Flash
DEBUG: Current (stlink) External (blackmagic, jlink, stlink)
- framework-mbed 5.51401.200110 (5.14.1)
Collecting mbed sources…
TypeError: argument of type ‘int’ is not iterable:
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\main.py”, line 156:
env.SConscript(“$BUILD_SCRIPT”)
File “C:\Users\fmukhtarif.platformio\packages\tool-scons\script..\engine\SCons\Script\SConscript.py”, line 541:
File “C:\Users\fmukhtarif.platformio\packages\tool-scons\script..\engine\SCons\Script\SConscript.py”, line 250:
exec file in call_stack[-1].globals
File “C:\Users\fmukhtarif.platformio\platforms\ststm32\builder\main.py”, line 98:
File “C:\Users\fmukhtarif.platformio\packages\tool-scons\script..\engine\SCons\Environment.py”, line 224:
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py”, line 62:
env.ProcessProjectDeps()
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py”, line 131:
project_lib_builder = env.ConfigureProjectLibBuilder()
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 1031:
lib_builders = env.GetLibBuilders()
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 956:
lb = LibBuilderFactory.new(env, lib_dir)
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 57:
obj = getattr(sys.modules[name], clsname)(env, path, verbose=verbose)
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 132:
self.process_extra_options()
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 560:
self._process_mbed_lib_confs()
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 583:
macros.update(self._mbed_lib_conf_parse_macros(mbed_lib_path))
File “C:\Users\fmukhtarif.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 608:
if “value” not in options:
====================================================== [FAILED] Took 7.79 seconds ======================================================
I try to update the platformio and update the mbed framework but nothing work. could you give me hint?
