So I have a library at /lib/mylib
, which contains files generated with codegeneration:
lib/
mylib/
mylib.proto
mylib.pb.h # generated
mylib.pb.c # generated
SConstruct # doesn't seem to run?
Where something like protoc mylib.proto
generates the two files
I’ve worked out that I can do it like this in build.py
from SCons.Script import DefaultEnvironment
env = DefaultEnvironment()
env['PROTOC'] = ...
# rebuild protobuf files
env.Command(
['messages.pb.c', 'messages.pb.h'],
'messages.proto',
r'$PROTOC --nanopb_out=. $SOURCES'
Adding extra_script = lib/mylib/build.py
to my .ini
file.
Is there any way to contain this config in the library folder?
