I’m new to PlatformIO and i’m trying to build multiple files.
I have in my src folder:
main.cpp:
#include "functions.h"
Serial.begin(9600);
int a = 2, b = 3, c;
c = multiply(a, b);
Serial.println(c);
delay(1000);
functions.c:
int multiply (int x, int y)
return (x * y);
I have in my include folder:
functions.h:
int multiply (int x, int y);
Everything seems to be correct here but when I try building this, the function multiply in main.cpp is not declared: src/main.cpp:10: undefined reference to `multiply(int, int)’
When intermixing C with C++ code, you must follow the rules regarding extern "C" declarations for name-mangling. See resourecs like this, this, this and this.
However, it might be that you don’t want to be writing C code in the first place. Arduino is a C++ framework, and in order to call any of its APIs, you need to writing code in .cpp files, not in .c files. So, I’d rather recommend you fully write the code in C++. Rename functions.c to functions.cpp and the functions.h header to
#ifndef FUNCTIONS_H_
#define FUNCTIONS_H_
