I’m posting to IDE because I observe relevant differences at that level but using CLI has the same results.
I’ve derived custom board from nrf52_dk (JFYI also tried from nrf52832_mdk with same results) for Zephyr framework. I’ve followed existing documentation here Enabling PlatformIO and Zephyr on custom hardware - Zephyr Project
Here’s my platform.ini
[env:mytest]
platform = nordicnrf52
board = mytest
framework = zephyr
monitor_speed = 115000
debug_tool = jlink
upload_protocol = jlink
And my mytest.json under boards dir
"build": {
"cpu": "cortex-m4",
"f_cpu": "64000000L",
"mcu": "nrf52832",
"zephyr": {
"variant": "mytest"
"connectivity": [
"bluetooth"
"debug": {
"jlink_device": "nRF52832_xxAA",
"svd_path": "nrf52.svd"
"frameworks": [
"zephyr"
"platforms": [
"nordicnrf52"
"name": "My Test",
"upload": {
"maximum_ram_size": 65536,
"maximum_size": 524288,
"protocol": "jlink",
"protocols": [
"jlink"
"url": "https://www.mytest.com",
"vendor": "My Test"
I notice two things:
In PlatformIO’s vscode panel, in Project Tasks, I don’t have a ‘Platform’ section (between General and Advanced section) with ‘Run menuconfig’, etc. I do have it for the nrf52_dk environment and everything works for that.
When I build - in IDE or by executing ‘pio run --environment mytest --verbose’ Cmake is unable to complete generation
Processing mytest (platform: nordicnrf52; board: mytest; framework: zephyr; monitor_speed: 115000; debug_tool: jlink; upload_protocol: jlink)
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/mytest.html
PLATFORM: Nordic nRF52 (7.0.0) > My Test
HARDWARE: NRF52832 64MHz, 64KB RAM, 512KB Flash
DEBUG: Current (jlink) External (jlink)
PACKAGES:- framework-zephyr 2.20500.210226 (2.5.0)
- framework-zephyr-canopennode 0.0.0-alpha+sha.468d350028
- framework-zephyr-civetweb 0.0.0-alpha+sha.e6903b80c0
- framework-zephyr-cmsis 0.0.0-alpha+sha.c3bd2094f9
- framework-zephyr-fatfs 0.0.0-alpha+sha.1d1fcc725a
- framework-zephyr-hal-nordic 0.0.0-alpha+sha.f0d54d8449
- framework-zephyr-hal-st 0.0.0-alpha+sha.b52fdbf4b6
- framework-zephyr-libmetal 0.0.0-alpha+sha.9d4ee2c3cf
- framework-zephyr-littlefs 0.0.0-alpha+sha.9e4498d1c7
- framework-zephyr-loramac-node 0.0.0-alpha+sha.3f545d76a2
- framework-zephyr-lvgl 0.0.0-alpha+sha.31acbaa36e
- framework-zephyr-mbedtls 0.0.0-alpha+sha.24d84ecff1
- framework-zephyr-mcuboot 0.0.0-alpha+sha.3fc59410b6
- framework-zephyr-mcumgr 0.0.0-alpha+sha.43845e883f
- framework-zephyr-mipi-sys-t 0.0.0-alpha+sha.75e671550a
- framework-zephyr-open-amp 0.0.0-alpha+sha.de1b85a130
- framework-zephyr-openthread 0.0.0-alpha+sha.1d668284a0
- framework-zephyr-segger 0.0.0-alpha+sha.38c79a447e
- framework-zephyr-sof 0.0.0-alpha+sha.b5b772dd61
- framework-zephyr-tfm-mcuboot 1.7.0-rc1
- framework-zephyr-tinycbor 0.0.0-alpha+sha.40daca97b4
- framework-zephyr-tinycrypt 0.0.0-alpha+sha.3e9a49d267
- framework-zephyr-trusted-firmware-m 0.0.0-alpha+sha.96340fb6c0
- tool-cmake 3.16.4
- tool-dtc 1.4.7
- tool-gperf 3.0.4
- tool-ninja 1.7.1
- tool-sreccat 1.164.0 (1.64)
- toolchain-gccarmnoneeabi 1.80201.181220 (8.2.1)
Reading CMake configuration…
– Application: /home/gobbled/zephyr
– Zephyr version: 2.5.0 (/home/gobbled/.platformio/packages/framework-zephyr)
– Found Python3: /home/gobbled/.platformio/penv/bin/python3.9 (found suitable exact version “3.9.2”) found components: Interpreter
– Board: mytest
– Cache files will be written to: /home/gobbled/.cache/zephyr
– Found dtc: /home/gobbled/.platformio/packages/tool-dtc/dtc (found suitable version “1.4.7”, minimum required is “1.4.6”)
– Found toolchain: gnuarmemb (/home/gobbled/.platformio/packages/toolchain-gccarmnoneeabi@1.80201.181220)
– Found BOARD.dts: /home/gobbled/zephyr/boards/arm/mytest/mytest.dts
– Generated zephyr.dts: /home/gobbled/.pio/build/mytest/zephyr/zephyr.dts
– Generated devicetree_unfixed.h: /home/gobbled/.pio/build/mytest/zephyr/include/generated/devicetree_unfixed.h
– Generated device_extern.h: /home/gobbled/.pio/build/mytest/zephyr/include/generated/device_extern.h
Parsing /home/gobbled/.platformio/packages/framework-zephyr/Kconfig
Loaded configuration ‘/home/gobbled/zephyr/boards/arm/mytest/mytest_defconfig’
Merged configuration ‘/home/gobbled/zephyr/prj.conf’
Configuration saved to ‘/home/gobbled/.pio/build/mytest/zephyr/.config’
Kconfig header saved to ‘/home/gobbled/.pio/build/mytest/zephyr/include/generated/autoconf.h’
– The C compiler identification is GNU 8.2.1
– The CXX compiler identification is GNU 8.2.1
– The ASM compiler identification is GNU
– Found assembler: /home/gobbled/.platformio/packages/toolchain-gccarmnoneeabi@1.80201.181220/bin/arm-none-eabi-gcc
– Configuring done
CMake Error at /home/gobbled/.platformio/packages/framework-zephyr/cmake/extensions.cmake:416 (add_library):
No SOURCES given to target: drivers__serial
/home/gobbled/.platformio/packages/framework-zephyr/cmake/extensions.cmake:393 (zephyr_library_named)
/home/gobbled/.platformio/packages/framework-zephyr/drivers/serial/CMakeLists.txt:3 (zephyr_library)CMake Generate step failed. Build files cannot be regenerated correctly.
========================== [FAILED] Took 1.75 seconds ==========================Environment Status Duration
mytest FAILED 00:00:01.750
nrf52_dk IGNORED
==================== 1 failed, 0 succeeded in 00:00:01.750 ====================
Am I missing something or is there a bug lurking here?
Thanks in advance
