Building Bin file
Does anyone have a tip on what could be the cause of the error message below?
Processing V450_2K4 (platform: https://github.com/platformio/platform-atmelmegaavr.git; board: ATtiny1624; framework: arduino) ---------------------------------------------------------------------------------------------------------------
CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/ATtiny1624.html
PLATFORM: Atmel mega AVR (1.9.0+sha.5002fb5) > ​​ATtiny1624
HARDWARE: ATTINY1624 5MHz, 2KB RAM, 16KB Flash
PACKAGES: - framework-arduino-megaavr-megatinycore @ 2.6.7 - toolchain-atmelavr @ 3.70300.220127 (7.3.0) LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain+, Compatibility ~ strict Found 20 compatible libraries Scanning dependencies... Dependency Graph |-- FastPID @ 1.3.2+sha.e00f476 |-- SerialEncoder @ 0.1.0+sha.f909d31 |-- settings |-- EEPROM @ 2 .1.3 |-- crc16 |-- Steinhart Building in release mode Compiling .pio/build/V450_2K4/src/main.cpp.o Compiling .pio/build/V450_2K4/src/packet_processor.cpp.o Linking .pio/build/V450_2K4/module_fw_V450_2K4_ATtiny1624_450_e0_h0_l0.elf Checking size .pio/build/V450_2K4/module_fw_V450_2K4_ATtiny1624_450_e0_h0_l0.elf
RAM: [= ] 14.6% (used 299 bytes from 2048 bytes)
Flash:[===== ] 51.0% (used 8360 bytes from 16384 bytes)
Building .pio/build/V450_2K4/module_fw_V450_2K4_ATtiny1624_450_e0_h0_l0.hex
Building binary file /home/gerard-giga/Software-hardware/Software/BMS/Diy_bms_Stuart_Pittaway/24-08-04 diyBMSv4ESP32-master/ATTINYCellModule /.pio/build/V450_2K4/module_fw_V450_2K4_ATtiny1624_450_e0_h0_l0.bin
Usage: avr-objcopy [option(s)] in-file [out-file] Copies a binary file, possibly transforming it in the process
The options are:
-I --input-target <bfdname> Assume input file is in format <bfdname>
-O --output-target <bfdname> Create an output file in format <bfdname>
-B --binary-architecture <arch> Set output arch, when input is arch-less
etc, etc.
avr-objcopy: supported targets: elf32-avr elf32-little elf32-big plugin srec symbolsrec verilog tekhex binary ihex *** [.pio/build/V450_2K4/module_fw_V450_2K4_ATtiny1624_450_e0_h0_l0.hex] Error 1
Thanks in advance
Your project name has a space for in it but your extra_script is badly written and doesn’t wrap the arguments into " quote characters so that paths with spaces can be used properly? What’s the full story here, aka the full platformio.ini?
Thank you,
Indeed it was the space.
Too much staring causes dashes😉.
Thanks again.
