I am struggling to prevent Platformio trying to pull header files (Ethernet.h
and SPI.h
) that are not part of the project. These are mentioned in the eModbus
library that is for both ESP32 and ESP8266. The library code but has these #include
lines surrounded by #ifdef
, that will not evaluate to true in the ESP8266 environment.
platformio.ini
[env:esp8285]
platform = espressif8266
board = esp8285
FauxmoESP=https://github.com/vintlabs/fauxmoESP
eModbus=https://github.com/eModbus/eModbus
board_build.flash_mode = dout
board_build.ldscript = eagle.flash.1m64.ld
monitor_filters = esp8266_exception_decoder
-DPIO_FRAMEWORK_ARDUINO_LWIP_HIGHER_BANDWIDTH
-DLOG_LEVEL=LOG_LEVEL_VERBOSE
upload_protocol = espota
upload_port = Gosund01
upload_flags =
--port=8266
--auth="XxXX"
The code containing the references to Ethernet.h
and SPI.h
is not even used in those files the project is using. If I will open the library code using those, the #ifdef
seems to be functional, the code is dimmed:
Nevertheless a buil is failing due to these files missing in ESP8266 environment:
> Executing task in folder SmartDose: C:\Users\Micha\.platformio\penv\Scripts\pio.exe run <
Processing esp8285 (platform: espressif8266; board: esp8285; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp8285.html
PLATFORM: Espressif 8266 (2.6.2) > Generic ESP8285 Module
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Found 47 compatible libraries
|-- <FauxmoESP> 3.2.0+sha.810d5d7
| |-- <ESPAsyncTCP> 1.2.2
| | |-- <ESP8266WiFi> 1.0
|-- <eModbus> 0.0.1+sha.27f3ec7
| |-- <Ethernet> 2.0.0
|-- <LittleFS(esp8266)> 0.1.0
|-- <ArduinoOTA> 1.0
| |-- <ESP8266mDNS> 1.2
|-- <ESP8266WebServer> 1.0
Archiving .pio\build\esp8285\libe3a\libESPAsyncTCP.a
Archiving .pio\build\esp8285\lib96b\libFauxmoESP.a
Compiling .pio\build\esp8285\lib0af\Ethernet\Dhcp.cpp.o
Compiling .pio\build\esp8285\lib0af\Ethernet\Dns.cpp.o
Compiling .pio\build\esp8285\lib0af\Ethernet\Ethernet.cpp.o
Compiling .pio\build\esp8285\lib0af\Ethernet\EthernetClient.cpp.o
In file included from .pio\libdeps\esp8285\Ethernet\src\Dhcp.cpp:7:0:
.pio\libdeps\esp8285\Ethernet\src\utility/w5100.h:18:17: fatal error: SPI.h: No such file or directory
* Looking for SPI.h dependency? Check our library registry!
* CLI > platformio lib search "header:SPI.h"
* Web > https://platformio.org/lib/search?query=header:SPI.h
#include <SPI.h>
compilation terminated.
In file included from .pio\libdeps\esp8285\Ethernet\src\Dns.cpp:8:0:
#include <SPI.h>
In file included from .pio\libdeps\esp8285\Ethernet\src\Ethernet.cpp:23:0:
#include <SPI.h>
*** [.pio\build\esp8285\lib0af\Ethernet\Dhcp.cpp.o] Error 1
*** [.pio\build\esp8285\lib0af\Ethernet\Dns.cpp.o] Error 1
*** [.pio\build\esp8285\lib0af\Ethernet\Ethernet.cpp.o] Error 1
In file included from .pio\libdeps\esp8285\Ethernet\src\EthernetClient.cpp:24:0:
#include <SPI.h>
*** [.pio\build\esp8285\lib0af\Ethernet\EthernetClient.cpp.o] Error 1
========================================================================= [FAILED] Took 8.29 seconds =========================================================================The terminal process "C:\Users\Micha\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
The Ethernet
library is mentioned in the dependency graph, but why?
There is a dependency in library.json
, but only for platform espressif32
"dependencies": [
"owner": "me-no-dev",
"name": "AsyncTCP",
"version": "*",
"platforms": ["espressif32"]
"name": "ESPAsyncTCP",
"version": "*",
"platforms": ["espressif8266"]
"name": "Ethernet",
"url": "https://github.com/maxgerhardt/Ethernet.git",
