Build_src_filter not accumulative across common and specific envs
I am creating a library, but I like to have test cases in the source that are cancelled out when it is distributed and used as a library.
Common [env] and specific [env:target] promise that the common applies to any target.
But when using build_src_filter it does not accumulate.
The following arrangement shows the problem…
[env]
platform = *
build_src_filter = +<*> -<[0-9][0-9]*.cpp> ;should work as base for all targets?
[env:01memio]
platform = native
build_src_filter = +<01memio.cpp> ;does not work.
[env:02sort]
platform = native
build_src_filter = -<[0-9][0-9]*.cpp> +<02sort.cpp> ;does not work.
[env:03speed]
platform = native
build_src_filter = +<*> -<[0-9][0-9]*.cpp> +<03speed.cpp> ;works!
But inside [env] build_src_filter is being assigned to…
[env]
platform = *
build_src_filter = +<*> -<[0-9][0-9]*.cpp> +<03speed.cpp> ;works with env:03speed as target!
[env:03speed]
platform = native
It seems that build_src_filter does not accumulate across common and specific environments.
If it is a how it works, it is relevant to mention in the manual.
Or is this a bug?
Exactly. This is documented behavior.
https://docs.platformio.org/en/latest/projectconf/interpolation.html
You need to interpolate the values, e.g., as seen here.
That explains it. Solved!
Thank you!
