I’m using Arduino for STM32. My application is designed to run along with bootloader, so I need to set custom location of interrupt vectors table.
When I try to pass custom vector table start address by defining VECT_TAB_ADDR, I get the following error:
TypeError: unhashable type: 'list':
File "C:\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 162:
File "C:\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 541:
File "C:\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "C:\.platformio\platforms\ststm32\builder\main.py", line 127:
File "C:\.platformio\packages\tool-scons\script\..\engine\SCons\Environment.py", line 224:
File "C:\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 67:
env.ProcessUnFlags(env.get("BUILD_UNFLAGS"))
File "C:\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 173:
all_flags = set(all_flags)
My platformio.ini
file’s relevant portion:
build_flags = -Wl,-T./my.ld -v -DVECT_TAB_ADDR=134238208
build_unflags = -DVECT_TAB_ADDR=134217728
Adding a space between -D
and VECT_TAB_ADDR
doesn’t help.
After adding some debug output in platformio.py
file, it became clear that all_flags
is a nested list: [['VECT_TAB_ADDR', '134217728']]
. After changing the line 173 in platformio.py
to all_flags = set(all_flags[0])
it doesn’t crash any more, but I don’t know if this is the right way.
Also, it still doesn’t work, the compilation process still gives a warning that VECT_TAB_ADDR is redefined. Apparently, this symbol is added to defines after build_unflags
is processed.
