It returned me two digits of year, month and day.
Recently it stopped worked after some platformio upgrade
I’m receiving error
Error: Invalid ‘C:\priv\platformio\sdmoto\platformio.ini’ (project configuration file): ‘’%’ must be followed by ‘%’ or ‘(’, found: ‘%date:~2,2%%date:~5,2%%date:~8,2%’’
So have you tried surrounding it with ( as it wants?
Seems like you’re trying to do a cmd.exe inline command evaluation when the compiler is executed. It would be much more safer, cleaner and cross-platform to use advanced scripting for that.
E.g., add extra_scripts = add_date.py to the platformio.ini
and in add_data.py at the root of the project
import datetime
Import("env")
curr_date = datetime.datetime.now()
year = str(curr_date.year)[2:] # ignore first 2 chars of year; 2020 -> 20
# code it in DDMMY
# day and month are zero-padded to length 2; e.g. 021120 -> 02.11.2020
date_str = f"{curr_date.day:02}{curr_date.month:02}{year}"
# append integer value to global defines
env.Append(CPPDEFINES=[
("FW_VERSION", int(date_str))
Thank you for the answer.
I already tried many combination with percent, parentheses, escape characters and nothing works.
eg
-D FW_VERSION=%(date)%
gives me
‘bad interpolation variable reference ‘%(date)%’’
Maybe there is a magic combination of characters that makes parser happy, but I can’t get it.
I’m absolutely sure that my method worked before some recent platformio upgrade. Just want to avoid having extra scripts necessary to compile sources.
I can use
FW_VERSION=$UNIX_TIME
but it require math to convert to YYMMDD
Well the question is here what was updated that broke it (though I don’t think command injection wasn’t intended in the first place). If it’s the PIO core that handles compilation differently, then, depending on how you installed it, you can install a different version, with e.g. pip in a PIO terminal, using pip uninstall platformio and pip install 'platformio==<some version>' commands with version from here.
The other thing that could have update is the “platform”, e.g. platform-atmelavr or whatever platform you’re compiling for. You can change the platform using e.g. platform = atmelavr@<version> commands with a version from the release page of the platform (example).
The Python advanced scripting is cross-platform for all operating systems and PIO is always installed on top of Python or (in the VSCode Plugin case) even brings its own Python3 interpreter. So that will always work. It’s the best option in my opinion, rather than depending on a command injection.
