I’m using the dynamic variables section within the paltform.ini very intensive.
[common]
build_flags = -DVERSION="1.2.3" '-DOTAAUTH="secret"' -DDEBUG="1" -DVAR1="1" -DVAR2="2" ....
lib_deps_builtin = SPI, Wire, ...
lib_deps_external = ArduinoJson@>5.6.0, WifiManager, ...
Hence, I would like to use this section separated in several lines per option due to readability reasons:
[common]
-DVERSION="1.2.3"
-DDEBUG="1"
-DVAR1="1"
-DVAR2="2"
lib_deps_builtin =
SPI,
Wire,
lib_deps_external =
ArduinoJson@>5.6.0,
WifiManager,
It tested several scenarios and in conclusion you can use comma separated options within different lines (like lib__deps__builtin). Build flags (bulid__flags), which are not comma separated, cannot be used in different lines. You get a compilation error.
Question:
- Is there another way to get a better readablity within the platform.ini?
- Will there be a such feature in the future?
Thanks,
GL
