Have been trying to get ble examples working through platformio on our board but have had no luck. The moment I add bluefruit.h as a header the build fails with lots of errors like the following
C:\Users\Jonathan.platformio\packages\framework-arduinoadafruitnrf52\libraries\Bluefruit52Lib\src\utility\bonding.cpp:221:10: error: ‘file’ was not declared in this scope
All related to bonding.cpp
Even with a very minimal setup this occurs. Here is .ini contents
[env:ble-test]
platform = nordicnrf52
board = adafruit_itsybitsy_nrf52840
And here is the most basic code that fails at compiling.
#include “Adafruit_TinyUSB.h”
#include “bluefruit.h”
void setup(){};
void loop(){};
This code does compile in the arduino ide so I’m not sure what I’m doing wrong, if there is a missing setting in the .ini, or if this is a platformio bug.
