I’ve been trying to use VSCode to build marlin for my skr 1.3 board that has a lpc1768. Building on my PC does not work and I get the following:
AssertionError: :
File "C:\Users\bencl\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 126: env.SConscript("$BUILD_SCRIPT")
File "C:\Users\bencl\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py",
line 605:
File "C:\Users\bencl\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 286:
File "C:\Users\bencl\.platformio\platforms\nxplpc-arduino-lpc176x\builder\main.py", line 136:
File "C:\Users\bencl\.platformio\packages\tool-scons\script\..\engine\SCons\Environment.py", line 224:
File "C:\Users\bencl\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 110:
224:
File "C:\Users\bencl\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 288:
env.ConvertInoToCpp()
224:
File "C:\Users\bencl\.platformio\penv\lib\site-packages\platformio\builder\tools\piomisc.py", line
198:
out_file = c.convert(ino_nodes)
IGNORED
1 failed, 0 succeeded in 00:00:00.720
IGNORED
Terminal will be reused by tasks, press any key to close it.atformio\builder\tools\piomisc.py", line
80:
assert self._gcc_preprocess(contents, out_file)
[FAILED] Took 0.72
^Might have butchered that because vscode outputted it in a tiny column (Mod edit: Added triple backtick ``` code formatting markup before and after output)
I have everything on same versions between computers and just can’t seem to get it to build, I’ve spent the last 3 or 4 days trying different things I’ve seen online and multiple reinstalls and nothing has worked. I have no idea what I’m doing really and would appreciate if someone was able to help.
