Bug? PlatformIO Esp32 doesn't upload via serial in debug mode
For some reason the PlatformIO environment doesn’t upload the debug build it creates when trying to enter debug mode (Run->Start Debugging) - for me at least. It will build it, but never uploads it. I’m using the esp-prog tool for debugging but want to keep the serial upload for circuitry reasons.
I can serial upload either release or debug builds fine when building/uploading, it is only during the debug sequence that it doesn’t upload.
This is my platform.ini:
[env:esp32thing_plus]
upload_port = COM19
build_type = debug
debug_tool = esp-prog
build_flags = -DCORE_DEBUG_LEVEL=5
Note I need the upload_port specified there as during regular upload platformio will incorrectly autodetect the esp-prog port and try to upload to that…
Any thoughts?
When you start a debug session, what does the “Debug Console” tab in VSCode say? There is critical info there.
Most likely you haven’t connected the debugger to the board correctly per this article.
