PlatformIO Community
Bricked Wemos d1 mini,visual studio code
#1
So I tried to update my wemo d1 mini (tasmota firmware [https://github.com/arendst/Sonoff-Tasmota] )
and damaged
Serial Monitor output:
l␌␄␃␌␌␄␄␌␌␄␄cl�{�␓��#�␄␄␃␌␄␄␌␌␄␄␌c␄��r�␄␌␂␄␄␌␌␌␄␌l`␃␜␛�␓�ol�{
…and to the infinity.
Is there any way to save it?
i aso tried this https://www.esp8266.com/viewtopic.php?p=67614.
thnx in advance
#2
That’s very little info. What environment did you select in the platformio.ini?
#3
run task–> wemos(upload). i did it 10000 times.
i dont know how to restore it from this state. i have 2 wemos in this condition
#4
Can you upload another firmware like https://github.com/platformio/platform-espressif8266/tree/develop/examples/arduino-wifiscan to it? Use the platformio.ini
[env:wemos]
platform = espressif8266
board = d1_mini_lite
i dont know how to run it. sorry.
i downloaded it and added it to vsc.
I added the lines in the specific example arduino-wifiscan.
then?
#6
In VSCode, click on the upload button in the toolbar. See http://docs.platformio.org/en/latest/ide/vscode.html#platformio-toolbar
#7
i see. with this folder there are not options in the toolbar . In tasmota folder exists.
#8
I think it would be easier if you just created a new project (see here) with the WeMos D1 mini Lite as board and copied the WiFiScan.ino into the new project’s src/ directory.
#9
okkkkk
platformio.ini
[env:d1_mini_lite]
[env:wemos]
TERMINAL:
Processing wemos (platform: espressif8266; board: d1_mini_lite; framework: arduino)
Verbose mode can be enabled via -v, --verbose option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini_lite.html
PLATFORM: Espressif 8266 > WeMos D1 mini Lite
HARDWARE: ESP8266 80MHz 80KB RAM (1MB Flash)
Converting WiFiScan.ino
Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF MODES: FINDER(chain) COMPATIBILITY(soft)
Collected 26 compatible libraries
Scanning dependencies…
|-- 1.0
Compiling .pioenvs\wemos\src\WiFiScan.ino.cpp.o
Compiling .pioenvs\wemos\src\main.cpp.o
Generating LD script .pioenvs\wemos\ld\eagle.app.v6.common.ld
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\BearSSLHelpers.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\CertStoreBearSSL.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\ESP8266WiFi.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiClient.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiClientSecureAxTLS.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiServer.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiServerSecureAxTLS.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o
Compiling .pioenvs\wemos\libbde\ESP8266WiFi\WiFiUdp.cpp.o
Archiving .pioenvs\wemos\libFrameworkArduinoVariant.a
Compiling .pioenvs\wemos\FrameworkArduino\Esp-version.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\Esp.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\FS.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\FunctionalInterrupt.cpp.o
Archiving .pioenvs\wemos\libbde\libESP8266WiFi.a
Compiling .pioenvs\wemos\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\IPAddress.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\MD5Builder.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\Print.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\Schedule.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\ScheduledFunctions.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\Stream.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\StreamString.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\Tone.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\Updater.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\WMath.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\WString.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\abi.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\base64.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\cbuf.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\cont.S.o
Compiling .pioenvs\wemos\FrameworkArduino\cont_util.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_eboot_command.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_flash_utils.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_i2s.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_main.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_noniso.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_phy.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_postmortem.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_si2c.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_sigma_delta.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_timer.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_waveform.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_wiring.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_wiring_analog.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_wiring_digital.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_wiring_pulse.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_wiring_pwm.c.o
Compiling .pioenvs\wemos\FrameworkArduino\core_esp8266_wiring_shift.c.o
Compiling .pioenvs\wemos\FrameworkArduino\debug.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\gdb_hooks.c.o
Compiling .pioenvs\wemos\FrameworkArduino\heap.c.o
Compiling .pioenvs\wemos\FrameworkArduino\libb64\cdecode.c.o
Compiling .pioenvs\wemos\FrameworkArduino\libb64\cencode.c.o
Compiling .pioenvs\wemos\FrameworkArduino\libc_replacements.c.o
Compiling .pioenvs\wemos\FrameworkArduino\pgmspace.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\sntp-lwip2.c.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs\spiffs_cache.c.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs\spiffs_check.c.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs\spiffs_gc.c.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs\spiffs_hydrogen.c.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs\spiffs_nucleus.c.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs_api.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\spiffs_hal.cpp.o
Compiling .pioenvs\wemos\FrameworkArduino\time.c.o
Compiling .pioenvs\wemos\FrameworkArduino\uart.c.o
Compiling .pioenvs\wemos\FrameworkArduino\umm_malloc\umm_malloc.c.o
Archiving .pioenvs\wemos\libFrameworkArduino.a
Linking .pioenvs\wemos\firmware.elf
.pioenvs\wemos\src\main.cpp.o: In function setup': main.cpp:(.text.setup+0x0): multiple definition ofsetup’
.pioenvs\wemos\src\WiFiScan.ino.cpp.o:WiFiScan.ino.cpp:(.text.setup+0x24): first defined here
.pioenvs\wemos\src\main.cpp.o: In function loop': main.cpp:(.text.loop+0x0): multiple definition ofloop’
.pioenvs\wemos\src\WiFiScan.ino.cpp.o:WiFiScan.ino.cpp:(.text.loop+0x84): first defined here
collect2.exe: error: ld returned 1 exit status
*** [.pioenvs\wemos\firmware.elf] Error 1
======================================================================================================== [ERROR] Took 7.89 seconds ========================================================================================================
================================================================================================================ [SUMMARY] ================================================================================================================
Environment d1_mini_lite        [ERROR]
Environment wemos               [ERROR]
======================================================================================================== [ERROR] Took 15.69 seconds ========================================================================================================
The terminal process terminated with exit code: 1
#10
You now have a main.cpp as well as WiFiScan.ino. Delete the main.cpp. Is this really a new, clean project?
#11
ok now we made proress
Processing d1_mini_lite (platform: espressif8266; board: d1_mini_lite; framework: arduino)
|-- <ESP8266WiFi> 1.0
Compiling .pioenvs\d1_mini_lite\src\WiFiScan.ino.cpp.o
Retrieving maximum program size .pioenvs\d1_mini_lite\firmware.elf
Checking size .pioenvs\d1_mini_lite\firmware.elf
DATA:    [===       ]  34.0% (used 27872 bytes from 81920 bytes)
PROGRAM: [===       ]  26.3% (used 252384 bytes from 958448 bytes)
Looking for upload port...
Auto-detected: COM6
Uploading .pioenvs\d1_mini_lite\firmware.bin
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
*** [upload] Error 2
======================================================================================================== [ERROR] Took 11.62 seconds ========================================================================================================
Retrieving maximum program size .pioenvs\wemos\firmware.elf
Checking size .pioenvs\wemos\firmware.elf
Auto-detected: COM6
Uploading .pioenvs\wemos\firmware.bin
======================================================================================================== [ERROR] Took 11.57 seconds ========================================================================================================
======================================================================================================== [ERROR] Took 23.20 seconds ========================================================================================================
#12
Ok then first of all remove the d1_mini_lite environment, the env:wemos already has everything.
I.e. your platformio.ini should be
[env:wemos]
ok the same failure.
Configuring upload protocol…
Looking for upload port…
Auto-detected: COM6
#14
Then put your Wemos into bootloader mode as described in https://www.esp8266.com/viewtopic.php?p=67614. (power Wemos, bridge D3 and GND, press reset button, remove bridge, re-upload)
#15
i did it all. All the ways . Nothing
#16
Then try first bridging D3 and GND, then powering it via USB and then uploading (while the bridge is still there).
#17
i did it. pressing the reset btn and without pressing. with short press and long. I smell dead end!!!
#18
without the bridge it fails in 2sec and with the brigde in11s
#19
I’m pretty sure it has something to do with the reset method of the board via the DTR / RTS pins (here, here).
You need to do the following things:
  1. ensure the Wemos is in bootloader mode. If you open a serial monitor at 74880 baud, and reset the board while D3 is connected the GND, the serial monitor should show a message like ets Jan 8 2013,rst cause:2, boot mode:(1,7). If this message is there, your ESP8266 is not dead. On Windows you can e.g. use hterm.exe as the serial monitor
  2. see if esptool.py can connect to it. Install it from Espressifs instructions as instructed here. Then see if the command esptool.py -p COM6 chip_id reads out some information. On my NodeMCUv2 it e.g. outputs
esptool.py v2.6
Serial port COM6
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
MAC: 2c:3a:e8:06:XX:XX
Uploading stub...
Running stub...
Stub running...
Chip ID: 0x000617b1
Hard resetting via RTS pin...
Options for reset methods for esptool.py are also listed here. If you get one of these to work, we know where the problem is.
#20
they are DEAD.
At 74880
0000, depc=0x00000000
Fatal exception (0):
epc1=0x40100003, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
and with reset nothing …
error.
thnx
