Hi, Max.
Thanks for replying.
Platformio compilation and uploading report:
> Executing task in folder GeradorDeSinalDeRotacao: C:\Users\Admin\.platformio\penv\Scripts\platformio.exe run --target upload <
Processing fm-devkit (platform: espressif32; board: fm-devkit; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/fm-devkit.html
PLATFORM: Espressif 32 (4.4.0) > ESP32 FM DevKit
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 2.0.4+sha.bd83727
- tool-mkfatfs @ 2.0.1
Found 34 compatible libraries
|-- LiquidCrystal_PCF8574 @ 1.3.0
| |-- Wire @ 2.0.0
|-- EEPROM @ 2.0.0
|-- Wire @ 2.0.0
Retrieving maximum program size .pio\build\fm-devkit\firmware.elf
Checking size .pio\build\fm-devkit\firmware.elf
RAM: [= ] 5.3% (used 17468 bytes from 327680 bytes)
Flash: [== ] 19.4% (used 253781 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM4
Uploading .pio\build\fm-devkit\firmware.bin
esptool.py v3.3
Serial port COM4
Connecting....
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: fc:f5:c4:19:94:94
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x0004efff...
Flash params set to 0x0220
Compressed 17280 bytes to 11968...
Writing at 0x00001000... (100 %)
Wrote 17280 bytes (11968 compressed) at 0x00001000 in 0.5 seconds (effective 274.3 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.1 seconds (effective 409.6 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 753.2 kbit/s)...
Compressed 254176 bytes to 140452...
Writing at 0x00010000... (11 %)
Writing at 0x0001ca58... (22 %)
Writing at 0x00024bf5... (33 %)
Writing at 0x0002a0df... (44 %)
Writing at 0x0002f49d... (55 %)
Writing at 0x000362c7... (66 %)
Writing at 0x0003ff29... (77 %)
Writing at 0x00045759... (88 %)
Writing at 0x0004acb5... (100 %)
Wrote 254176 bytes (140452 compressed) at 0x00010000 in 3.9 seconds (effective 527.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
============================================ [SUCCESS] Took 10.98 seconds ============================================
Platformio.ini content:
[env:fm-devkit]
board = fm-devkit
platform_packages = platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
;lib_deps = mathertel/LiquidCrystal_PCF8574@^2.0.0
lib_deps = mathertel/LiquidCrystal_PCF8574@1.3.0
Arduino IDE compilation and uploading report:
O sketch usa 224396 bytes (17%) de espaço de armazenamento para programas. O máximo são 1310720 bytes.
Variáveis globais usam 14476 bytes (4%) de memória dinâmica, deixando 313204 bytes para variáveis locais. O máximo são 327680 bytes.
esptool.py v2.6
Serial port COM4
Connecting.....
Chip is ESP32D0WDQ6 (revision 1)
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Auto-detected Flash size: 8MB
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 2520.6 kbit/s)...
Flash params set to 0x023f
Compressed 15328 bytes to 9993...
Wrote 15328 bytes (9993 compressed) at 0x00001000 in 0.2 seconds (effective 700.7 kbit/s)...
Compressed 224512 bytes to 112552...
Wrote 224512 bytes (112552 compressed) at 0x00010000 in 1.9 seconds (effective 954.4 kbit/s)...
Compressed 3072 bytes to 144...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.0 seconds (effective 945.2 kbit/s)...
Leaving...
Arduino IDE board configuration:
(previous image replaced by a better one - Edited by NormanDunbar (moderator) to format code segments.
