SOLVED !!!
I have solved this problem, so for anyone who lands here with similar problems, please see below
My code is now …
// Trev's Slider experiment
// https://github.com/Bodmer/TFT_eWidget
#include <FS.h>
#include <SD.h>
#include <SPI.h>
#include <TFT_eSPI.h>
#include <TFT_eWidget.h> // Widget library
// Define CS lines stuff
TFT_eSPI tft = TFT_eSPI();
#define TOUCH_CS 5 //CS pin on TFT screen
#define TFT_CS 15 //CS pin on TFT screen
#define SD_CS 22 //CS Pin on SD card reader
uint8_t TFT_Line = 20;
// This is the file name used to store the calibration data
// The SPIFFS file name must start with "/".
#define CALIBRATION_FILE "/TouchCalData2"
// Set REPEAT_CAL to true instead of false to run new calibration
#define REPEAT_CAL false
TFT_eSprite knob = TFT_eSprite(&tft); // Sprite for the slide knob
SliderWidget s1 = SliderWidget(&tft, &knob); // Slider 1 widget
// TOUCH COORDINATES
uint16_t t_x = 0, t_y = 0; // To store the touch coordinates
// ############ CALIBRATE TOUCH SCREEN ##############
void touch_calibrate() {
uint16_t calData[5];
uint8_t calDataOK = 0;
// check file system exists
if (!SPIFFS.begin()) {
Serial.println("formatting file system");
SPIFFS.format();
SPIFFS.begin(); }
// check if calibration file exists and size is correct
if (SPIFFS.exists(CALIBRATION_FILE)) {
if (REPEAT_CAL) {
// Delete if we want to re-calibrate
SPIFFS.remove(CALIBRATION_FILE);
} else {
File f = SPIFFS.open(CALIBRATION_FILE, "r");
if (f) {
if (f.readBytes((char *)calData, 14) == 14)
calDataOK = 1;
f.close();
// Touch screen calibration already done and DATA OK ?????
if (calDataOK && !REPEAT_CAL) {
tft.setTouch(calData); // calibration data valid ???? = EXIT ------
} else { // data not valid so recalibrate ---------------
tft.fillScreen(TFT_BLACK);
tft.setCursor(20, 0);
tft.setTextFont(2);
tft.setTextSize(1);
tft.setTextColor(TFT_WHITE, TFT_BLACK);
tft.println("Touch corners as indicated");
tft.setTextFont(1);
tft.println();
if (REPEAT_CAL) {
tft.setTextColor(TFT_RED, TFT_BLACK);
tft.println("Set REPEAT_CAL to false to stop this running again!");
tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
tft.setTextColor(TFT_GREEN, TFT_BLACK);
tft.println("Calibration complete!");
// now store data -----------------------------------------------------------
File f = SPIFFS.open(CALIBRATION_FILE, "w");
if (f) {
f.write((const unsigned char *)calData, 14);
f.close();
// SETUP ##########################################################
tft.begin();
tft.setRotation(4);
// Calibrate the touch screen and retrieve the scaling factors
touch_calibrate();
// Draw slider
s1.createSlider(40, 200, TFT_BLUE, TFT_BLACK, V_SLIDER);
s1.createKnob(60, 20, 5, TFT_WHITE, TFT_RED);
s1.setSliderScale(200, 0, 2000);
s1.drawSlider(200, 100);
s1.setSliderPosition(0);
// LOOP ###########################################################
static uint32_t scanTime = millis();
// Scan for touch every 50ms
if (millis() - scanTime >= 20) {
// Pressed will be set true if there is a valid touch on the screen
if( tft.getTouch(&t_x, &t_y, 0) ) {
if (s1.checkTouch(t_x, t_y)) {
Serial.print("Slider 1 = "); Serial.println(s1.getSliderPosition());
My PIO.ini is …
[env:nodemcu-32s]
board = nodemcu-32s
bodmer/TFT_eSPI@^2.5.43
bodmer/TFT_eWidget @ ^0.0.6
SD
lib_ignore = AzureIoTHubMQTTClient //=> this one also has an SD.h file which caused trouble earlier
-D USER_SETUP_LOADED
-D ILI9488_DRIVER
-D TFT_WIDTH=320
-D TFT_HEIGHT=480
-D TFT_RST=4
-D TFT_DC=2
;TFT
-D TFT_SCLK=18
-D TFT_MOSI=23
-D TFT_MISO=19
-D TFT_CS=15
;TOUCH
-D TOUCH_SCLK=18
-D TOUCH_DIN=23 ;MOSI
-D TOUCH_DO=19 ;MISO
-D TOUCH_CS=5
;SD
-D SD_SCLK=18
-D SD_MOSI=23
-D SD_MISO=19
-D SD_CS=22
;FONTS
-D LOAD_GLCD=1
-D LOAD_FONT2
-D LOAD_FONT3
-D LOAD_FONT4
-D LOAD_FONT6
-D LOAD_FONT7
-D LOAD_FONT8
-D LOAD_GFXFF
-D SMOOTH_FONT
;SPI Clock
-D SPI_FREQUENCY=40000000
SOLUTION
The key point is that in Bodmer’s example, the void setup() call to touch_calibrate() was …
void setup()
tft.begin();
tft.setRotation(4);
if (REPEAT_CAL) {
touch_calibrate();
So, if REPEAT_CAL is false (= don’t calibrate again), then touch_calibrate() is never ever called, and so the previous calibration data is NEVER retrieved.
My new setup …
void setup()
tft.begin();
tft.setRotation(4);
touch_calibrate();
Call tft.setRotation(4) FIRST, before any calibration.
Then touch_calibrate() is called regardless of the state of REPEAT_CAL.
Then in touch_calibrate(), if the REPEAT_CAL is false, it skips a new calibration, to just retrieve the old calibration data.
Trevor
