I am trying to use the board genericSTM32H750VB but am getting an error. Any suggestions?
I think it’s a new board that was added recently but it’s already in the official doc.
https://docs.platformio.org/en/latest/boards/ststm32/genericSTM32H750VB.html#configuration
Platformio core version
Executing task: C:\Users\user\.platformio\penv\Scripts\platformio.exe upgrade
You're up-to-date!
PlatformIO 6.1.11 is currently the newest version available.
Build error
Executing task: C:\Users\user\.platformio\penv\Scripts\platformio.exe run
Processing my_env (platform: ststm32; board: genericSTM32H750VB)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------UnknownBoard: Unknown board ID 'genericSTM32H750VB'
Platformio.ini
[env:my_env]
platform = ststm32
; test_filter = serial_packets/test_serial_packets_client
; debug_test = serial_packets/test_serial_packets_client
extra_scripts = extra_script.py
; board = my_genericSTM32H750VBT6
board = genericSTM32H750VB
; Linker file is from cube ide.
board_build.ldscript = STM32H750VBTX_FLASH.ld
debug_tool = stlink
upload_protocol = stlink
debug_build_flags = -Os -g3 -ggdb3
; debug_init_break = tbreak app_main
debug_init_break = tbreak none
test_framework = unity
test_port = COM6
monitor_port = COM6
lib_archive = no
check_skip_packages = yes
lib_ldf_mode=chain+
# cube_ide is automatically populated by cube_ide/update_platformil.py
# startup contains the processor startup code and is based on
# cube_ide/core/src/main.c. The rest of the libraries are detected
# automatically.
cube_ide
startup
-fmax-errors=5
-Werror
-mfpu=fpv5-sp-d16
-mfloat-abi=hard
-Wl,-Map,${BUILD_DIR}/firmware.map
-mthumb
-D DEBUG
-D USE_HAL_DRIVER
-DSTM32_THREAD_SAFE_STRATEGY=4
-fstack-usage
-std=gnu11
-Ilib/cube_ide/Core/Inc
-Ilib/cube_ide/Core/ThreadSafe
-Ilib/cube_ide/Drivers/CMSIS/Device/ST/STM32H7xx/Include
-Ilib/cube_ide/Drivers/CMSIS/Include
-Ilib/cube_ide/Drivers/STM32H7xx_HAL_Driver/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Core/Inc
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/Include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F
-Ilib/cube_ide/Middlewares/Third_Party/FatFs/src
-Ilib/cube_ide/USB_DEVICE/App
-Ilib/cube_ide/USB_DEVICE/Target
-Ilib/cube_ide/FATFS/App
-Ilib/cube_ide/FATFS/Target
-D CONFIG_MAX_PACKET_DATA_LEN=1000
-D CONFIG_MAX_PENDING_COMMANDS=5
