Beginner with platformio.ini
I am using windows 10 wishing to setup mbed debugging for st boards. My platformio.ini is:
[env:nucleo_f767zi]
platform = ststm32
framework = mbed
board = nucleo_f767zi
upload_port = COM[8]
upload_protocol = stlink
debug_tool = custom
debug_server =
  $PLATFORMIO_CORE_DIR/?????/openocd
  -f
  $PLATFORMIO_CORE_DIR/?????/tool-openocd/scripts/board/st_nucleo_f7.cfg
When I run debugging in vscode I get the following
Reading symbols from nucleo_f767zi/firmware.elf...
done.
PlatformIO Unified Debugger -> ly/pio-debug
GNU MCU Eclipse OpenOCD, 64-bitOpen On-Chip Debugger 0.10.0+dev-00593-g23ad80df4 (2019-04-22-20:25)
Licensed under GNU GPL v2
For bug reports, read
	openocd.bugs.html
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 2000 kHz
Info : STLINK V2J29M18 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.269404
Info : stm32f7x.cpu: hardware has 8 breakpoints, 4 watchpoints
xPSR: 0x81000000 pc: 0x08000764 msp: 0x2007ffc0
Info : device id = 0x10016451
Info : flash size = 2048 kbytes
Info : Single Bank 2048 kiB STM32F76x/77x found
Info : flash size = 1024 bytes
initialize (ticker=ticker@entry=0x8009858 <us_data>) at mbed_ticker_api.c:33
33	    if (ticker->queue->initialized) {
Temporary breakpoint 1 at 0x80038b0: file src\main.cpp, line 6.
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
adapter speed: 1800 kHz
xPSR: 0x01000000 pc: 0x0800161c msp: 0x20080000
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1012). Workaround: increase "set remotetimeout" in GDB
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
adapter speed: 4000 kHz
Loading section .text, size 0xa33c lma 0x8000000
Loading section .ARM.exidx, size 0x8 lma 0x800a33c
Loading section .data, size 0xad0 lma 0x800a344
Start address 0x800161c, load size 44564
Transfer rate: 16 KB/sec, 8912 bytes/write.
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
Temporary breakpoint 1, main () at src\main.cpp:6
6	int main() {
Breakpoint 2, main () at src\main.cpp:9
9	        wait(0.5);
Please advise how I may improve my platformio.ini file?
Many thanks,
Kevin
So you want a cleaner platformio.ini?
Well given that PlatformIO already has the right OpenOCD file
There should be no difference between your custom setup and PlatformIO’s default. What happens you remove the debug_tooland debug_server lines? After all, your debug session seems to be working already.
Thank you for your reply: maxgerhardt. I removed the lines as suggested and this is the result:
debug02082019c
Do I need the upload lines?
Can I set a speed?
How do I introduce a scrolling textbox or is it automatic in this forum?
Many thanks,
Kevin.
Triple backticks ``` (should be the key to the left of the 1 on your number key row) before and after where you’re going to insert the code/block text. :slightly_smiling_face:
Thank you pfeerick! That’s quick and easy.
@maxgerhardt
Thank you maxgerhardt.
The default upload tool is already stlink, so you also don’t need it.
Which speed? Flashing speed, monitor baud?
Thank you Max for your reply. When I first installed platformio plus vscode I used:
[env:nucleo_f767zi]
platform = ststm32
framework = mbed
and the debugger failed.
hence I tried adding all the extra lines. Now the only extra line is:
and it still works!
Is this a requirement of only Windows 10?
Next question:
“Info : Unable to match requested speed 2000 kHz, using 1800 kHz”
“Unable to match requested speed 2000 kHz, using 1800 kHz”
I did not set 2000kHz?
Am I using the unified debugger or am I using GNU GDB?
Is there a requirement to have GDB installed?
Must it be a precise reversion “C:\Program Files (x86)\GNU Tools ARM Embedded\6 2017-q2-update\bin”?
How does the unified debugger relate to GDB?
Sorry for the delay in reply I am in New Zealand.
Kevin.
