With all default settings? Screenshot of Arduino IDE → Tools menu?
Ok, I have the basic example working in Vscode:
Needed to put a space after the -D to separate it from the rest of the text in the build_flags line. I still can’t get it to work for the original project, but evidently that must be the way that the project is set up. The basic example shows it works in principle.
Can’t capture the open menu unfortunately, but yes, with all default settings except for “Use CDC on Boot” which has to be set to “Enable”. I imagine it does the same thing as the ‘-D ARDUINO_USB_CDC_ON_BOOT=1’ line in platformio.ini. The Tools diaglog closes as soon as I hit ‘Print Screen’.
What’s the full platformio.ini
for the full project?
Ok, here is the full platformio.ini as requested:
[platformio]
src_dir = src/
default_envs = AR488-ESP32-Rev4
[avr]
build_flags = -D USE_MACROS -D HAS_HELP_COMMAND
[env:uno]
extends = avr
board = uno
${avr.build_flags}
-D AR488_UNO
[env:micro]
extends = avr
board = micro
-D AR488_MEGA32U4
[env:mega2560_D]
extends = avr
board = megaatmega2560
${avr.build_flags}
-D AR488_MEGA2560 -D AR488_MEGA2560_D
[env:mega2560_E1]
extends = avr
${avr.build_flags}
-D AR488_MEGA2560 -D AR488_MEGA2560_E1
[env:mega2560_E2]
extends = avr
${avr.build_flags}
-D AR488_MEGA2560 -D AR488_MEGA2560_E2
[env:f303k8]
platform = ststm32
board = nucleo_f303k8
-D AR488_CUSTOM -D USE_INTERRUPTS
-D DIO1=PB6 -D DIO2=PB7 -D DIO3=PA12 -D DIO4=PA10
-D DIO5=PF0 -D DIO6=PF1 -D DIO7=PA8 -D DIO8=PA11
-D IFC=PA1 -D NDAC=PA0 -D NRFD=PB3 -D DAV=PA4
-D EOI=PB0 -D SRQ=PB4 -D REN=PB5 -D ATN=PA9
[env:f303k8-161]
platform = ststm32
-D SN7516X -D SN7516X_TE=PA5 -D SN7516X_DC=PB3
-D DIO1=PA9 -D DIO2=PA10 -D DIO3=PA12 -D DIO4=PB4
-D DIO5=PB6 -D DIO6=PF0 -D DIO7=PF1 -D DIO8=PA8
-D REN=PA11 -D IFC=PB5 -D NDAC=PB0 -D NRFD=PA4
-D DAV=PA7 -D EOI=PA0 -D ATN=PA1 -D SRQ=PB7
[esp32]
-D AR488_CUSTOM
-D USE_MACROS
-D HAS_HELP_COMMAND
[env:ttgo-t8-161]
extends = esp32
board_build.partitions = ttgo.csv
${esp32.build_flags}
-D AR488_WIFI_ENABLE
-D BOARD_HAS_PSRAM
-D AR488_BT_ENABLE
-D SN7516X -D SN7516X_TE=4 -D SN7516X_DC=21
-D DIO1=34 -D DIO2=35 -D DIO3=32 -D DIO4=33
-D DIO5=25 -D DIO6=26 -D DIO7=27 -D DIO8=14
-D REN=13 -D IFC=15 -D NDAC=22 -D NRFD=19
-D DAV=23 -D EOI=18 -D ATN=5 -D SRQ=2
extends = esp32
-D BOARD_HAS_PSRAM
-D AR488_BT_ENABLE
-D SN7516X -D SN7516X_TE=15 -D SN7516X_DC=2
-D SN7516X_SC=0 # for 75162
-D DIO1=33 -D DIO2=32 -D DIO3=26 -D DIO4=25
-D DIO5=14 -D DIO6=27 -D DIO7=13 -D DIO8=12
-D REN=23 -D IFC=22 -D NDAC=21 -D NRFD=19
-D DAV=18 -D EOI=17 -D ATN=4 -D SRQ=16
[env:lolin32-161]
extends = esp32
board = lolin32
# -D SN7516X_SC=0
-D DIO1=32 -D DIO2=33 -D DIO3=25 -D DIO4=26
-D DIO5=27 -D DIO6=14 -D DIO7=12 -D DIO8=13
-D REN=22 -D IFC=21 -D NDAC=19 -D NRFD=23
-D DAV=18 -D EOI=17 -D ATN=16 -D SRQ=4
[esp32v2]
platform = https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
platform_packages =
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.14
-D AR488_CUSTOM
-D USE_MACROS
[env:esp32s2-161]
extends = esp32v2
board = esp32-s2-saola-1
${esp32v2.build_flags}
-D BOARD_HAS_PSRAM
-D SN7516X -D SN7516X_TE=17 -D SN7516X_DC=21
-D DIO1=1 -D DIO2=2 -D DIO3=3 -D DIO4=4
-D DIO5=5 -D DIO6=6 -D DIO7=7 -D DIO8=8
-D REN=9 -D IFC=10 -D NDAC=11 -D NRFD=12
-D DAV=13 -D EOI=14 -D ATN=15 -D SRQ=16
[env:lolin32-161-v2]
extends = esp32v2
board = lolin32
[env:AR488-ESP32-Rev4]
upload_protocol = esptool
-D AR_ESP32S2_USB_CDC=Serial
-D AR488_CUSTOM
-D DIO1=8 -D DIO2=9 -D DIO3=10 -D DIO4=11
-D DIO5=12 -D DIO6=13 -D DIO7=14 -D DIO8=15
-D REN=26 -D IFC=38 -D NDAC=33 -D NRFD=34
-D DAV=40 -D EOI=35 -D ATN=36 -D SRQ=37
[env:AR488-ESP32-Rev5]
-D AR488_CUSTOM
-D SN7516X -D SN7516X_TE=17 -D SN7516X_DC=38 -D SN7516X_PE=1
-D REN=21 -D IFC=4 -D NDAC=33 -D NRFD=34
-D DAV=5 -D EOI=35 -D ATN=36 -D SRQ=37
Thank you for having a look.
A short term quick & dirty workaround that accommodates both scenarios.
Run two versions of VS Code, they seem to happily coexist and operate concurrently on the same Win 11 Pro machine.
Run one with Platform IO, my preferred option and which covers a large proportion of my code, and run the other with the pioarduino extension.
In my case I have a standard VSC instance plus a VSC Insider version.
Cheers
That’s an interesting idea. I guess that’s one way of getting around it.
