Hi @maxgerhardt,
your debug_init_cmds were spot-on. Instead of emptying out debug_load_cmds, I set debug_load_mode = manual to prevent firmware upload.
My overall process:
Start a debug sesseion with no modifications to
platformio.ini. This ensures that a debug image is uploaded and running on the target. -
Stop the debugging session but leave the target powered.
Extend
platformio.inias follows:debug_load_mode = manual ; do not reset board upon connecting debug_init_cmds = target extended-remote $DEBUG_PORT $INIT_BREAK monitor halt monitor init monitor resume ; this is a guess based on the openocd commands ; in http://openocd.org/doc/html/General-Commands.html ; maybe also needs monitor reset run ; or monitor reset init -
Start another debug session.
I can now stop the target, set breakpoints, etc. - the full debugging experience.
I can observe from the serial port that the target did not reset.
I will file a feature request for the PlatformIO IDE to offer this as a regular feature, so that you can select whether you want the regular build to build/upload a release or debug image and whether you want the debugger to reset/attach.
EDIT: Feature Request
Thank you!
Damian
