Hello everyone, hope you are doing great! So, I built some basic projects (like blink) on this platform using ATTINY85 and USBTiny as programmer on a Raspberry Pi 4. All is well. But when I used the same code for configuring a project to ATmega8, I get this warning:
Processing program_via_USBtinyISP (platform: atmelavr)
Found 0 compatible libraries
Compiling .pio/build/program_via_USBtinyISP/src/main.o
avr-gcc: error: missing device or architecture after '-mmcu='
*** [.pio/build/program_via_USBtinyISP/src/main.o] Error 1
====================================================== [FAILED] Took 1.68 seconds ======================================================
Environment Status Duration
ATmega8 SUCCESS 00:00:04.074
program_via_USBtinyISP FAILED 00:00:01.680
================================================= 1 failed, 1 succeeded in 00:00:05.753 =================================================
The terminal process "platformio 'run'" terminated with exit code: 1.
Here is the configuration:
[env:ATmega8]
board = ATmega8
; change microcontroller
;board_build.mcu = atmega8
; change MCU frequency
board_build.f_cpu = 8000000L
board_fuses.lfuse = 0xE4
board_fuses.hfuse = 0xD9
upload_protocol = usbtiny
[env:program_via_USBtinyISP]
upload_protocol = custom
upload_flags =
-C
; use "tool-avrdude-megaavr" for the atmelmegaavr platform
-p
$BOARD_MCU
-c
usbtiny
I have extensively search for the problem in the code and on the forums (examples and how to) but simply cant find whats the problem?
Thank you for your time and effort! Cheers!
