I have a problem upload the hex flie to ATMEGA32
My ini file:
[env:ATmega32]
board = ATmega32
upload_protocol = atmelice_isp
upload_port = usb
upload_flags =
-pm32
-catmelice_isp
-v
-Uhfuse:w:0x89:m
-Ulfuse:w:0xFF:m
My programmer is ATMELICE.
Response from Platformio:
AVAILABLE: atmelice_isp
CURRENT: upload_protocol = atmelice_isp
Looking for upload port...
Use manually specified: usb
Uploading .pio\build\ATmega32\firmware.hex
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
System wide configuration file is "C:\Users\user\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : usb
Using Programmer : atmelice_isp
Overriding Baud Rate : 115200
avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J41800087943
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
AVR Part : ATmega32
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 10 64 0 no 1024 4 0 9000 9000 0xff 0xff
flash 33 6 64 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
Programmer Type : JTAG3_ISP
Description : Atmel-ICE (ARM/AVR) in ISP mode
Vtarget : 5.0 V
SCK period : 125.00 us
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9502 (probably m32)
avrdude: safemode: hfuse reads as 89
avrdude: reading input file "0x89"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0x89:
avrdude: load data hfuse data from input file 0x89:
avrdude: input file 0x89 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: verifying ...
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file ".pio\build\ATmega32\firmware.hex"
avrdude: writing flash (344 bytes):
Writing | avrdude: stk500v2_command(): warning: Command timed out
avrdude: stk500v2_paged_write: write command failed
Thanks for any suggestions.
