Hello
I had a stroke! I do not write well
A problem I think it’s nothing but serious but it’s blocking
Processing nodemcu-32s (platform: espressif32; board: nodemcu-32s; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------Library Manager: Installing Hash
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (4.4.0) > NodeMCU-32S
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.220626 (2.0.3)
Found 35 compatible libraries
|-- AsyncTCP @ 1.1.1
|-- ESP Async WebServer @ 1.2.3
| |-- AsyncTCP @ 1.1.1
| |-- FS @ 2.0.0
| |-- WiFi @ 2.0.0
|-- AsyncElegantOTA @ 2.2.7
| |-- AsyncTCP @ 1.1.1
| | |-- AsyncTCP @ 1.1.1
| | |-- FS @ 2.0.0
| | |-- WiFi @ 2.0.0
| |-- FS @ 2.0.0
| |-- Update @ 2.0.0
| |-- WiFi @ 2.0.0
|-- WiFi @ 2.0.0
Linking .pio\build\nodemcu-32s\firmware.elf
c:/users/rserr/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\nodemcu-32s\lib4d6\libESP Async WebServer.a(WebAuthentication.cpp.o):(.literal._ZL6getMD5PhtPc+0x4): undefined reference to `mbedtls_md5_starts'
c:/users/rserr/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\nodemcu-32s\lib4d6\libESP Async WebServer.a(WebAuthentication.cpp.o): in function `getMD5(unsigned char*, unsigned
short, char*)':
F:\Data Jeanne\PlatformIO\AsyncElegantOTA/.pio/libdeps/nodemcu-32s/ESP Async WebServer/src/WebAuthentication.cpp:73: undefined reference to `mbedtls_md5_starts'
*** [.pio\build\nodemcu-32s\firmware.elf] Error 1
=================================================== [FAILED] Took 18.00 seconds ===================================================
The terminal process "C:\Users\rserr\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
What is the problem
Thank you
[env:nodemcu-32s]
board = nodemcu-32s
upload_port = COM6
me-no-dev/AsyncTCP@^1.1.1
me-no-dev/ESP Async WebServer@^1.2.3
ayushsharma82/AsyncElegantOTA@^2.2.7
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#elif defined(ESP32)
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <AsyncElegantOTA.h>
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
AsyncWebServer server(80);
void setup(void) {
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(200, "text/plain", "Hi! I am ESP32.");
AsyncElegantOTA.begin(&server); // Start ElegantOTA
server.begin();
Serial.println("HTTP server started");
void loop(void) {
