I am just trying out the STM32 Nucleo using l476RG and mbed and this is an example program that I copied and modified from the STMicro site. This compiles and runs on the on-line mbed compiler by ST.
#include "mbed.h"
#include "rtos.h"
DigitalOut led1(D7);
DigitalOut led2(D8);
Thread thread;
void led2_thread() {
while (true) {
led2 = !led2;
wait(1.0);
int main() {
thread.start(led2_thread);
while (true) {
led1 = !led1;
wait(0.135);
When I do the same thing with Platformio and VS code, I get the following errors:
Compiling .pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/integration/basic/main.o
arm-none-eabi-g++: error trying to exec '/Users/donblack/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/cc1plus': execv: Argument list too long
Compiling .pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/mbed_drivers/c_strings/main.o
*** [.pio/build/nucleo_l4476RG/src/main.o] Error 1
Compiling .pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/mbed_drivers/dev_null/main.o
*** [.pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/events/queue/main.o] Error 1
*** [.pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/integration/basic/main.o] Error 1
*** [.pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/mbed_drivers/c_strings/main.o] Error 1
*** [.pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/mbed_drivers/dev_null/main.o] Error 1
This is my .ini file:
[env:nucleo_l4476RG]
platform = ststm32
board = nucleo_l476rg
framework = mbed
#mbed-os
#build_flags = -D PIO_FRAMEWORK_MBED_RTOS_PRESENT
I have tried using mbed-os with lib-deps and without, and it makes no difference.
Thanks in advance for any help or advice.
Don
This seems like an artefact to me when you added mbed-os
to the lib_deps
folder. The resulting deep folder structure and the include paths overflow the maximum length handled by the operating system. PIO has to handle it differently.
Please remove the .pio\libdeps
folder entirely, and do not re-add mbed-os
, but do re-add the build_flags
line, and retry compilation.
Hello Max,
Thank you for your reply. I did as you suggested by removing the .pio\libdeps folder and adding the build_flags. I still get the error messages:
> Executing task: platformio run <
Processing nucleo_l4476RG (platform: ststm32; board: nucleo_l476rg; framework: mbed)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_l476rg.html
PLATFORM: ST STM32 5.7.0 > ST Nucleo L476RG
HARDWARE: STM32L476RGT6 80MHz, 128KB RAM, 1MB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, jlink)
PACKAGES: toolchain-gccarmnoneeabi 1.70201.0 (7.2.1), framework-mbed 5.51401.191023 (5.14.1)
Collecting mbed sources...
Found 2 compatible libraries
|-- <mbed-os>
Compiling .pio/build/nucleo_l4476RG/src/main.o
Compiling .pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/events/queue/main.o
Compiling .pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/mbed_drivers/echo/main.o
*** [.pio/build/nucleo_l4476RG/lib322/mbed-os_ID2499/TESTS/mbed_drivers/echo/main.o] Error 1
============================================================================ [FAILED] Took 76.21 seconds ============================================================================
Here is the .ini file:
;PlatformIO Project Configuration File
platform = ststm32
framework = mbed
Perhaps I should remove all the Frameworks associated with STM32 and reload them?
Thanks again for your help – sorry for being useless with this, but I am really confused.
Don
|-- <mbed-os>
The mbed-os “library” is still in the dependency graph, which is the source of the error. Can you please remove your entire .pio\
folder in the project. Have you installed this library in the global library space by any chance? If yes, open a PIO terminal and execute
pio lib uninstall mbed-os
and attempt recompilation.
Thanks, Max.
This solution eliminated the error regarding the argument list too long. I still have errors related to RTOS, but I will attempt to get them worked out.
Thanks again for your fast response and help.
Don
