i try first time platformio and i installed with Atom.
if i start a new project and i connect a arduino Uno on Com-Port (USB) then upload works fine.
if i start newe Project with mega2560 board and i try to upload then i get some error messages and upload no work
c:/users/xxxxx/.platformio/packages/toolchain-atmelavr/bin/…/lib/gcc/avr/5.4.0/…/…/…/…/avr/bin/ld.exe: cannot open output file .pioenvs\megaatmega2560\firmware.elf: No such
file or directory
what i can do?
best regards
Achim
i try now again and get this errors
Configuring upload protocol…
AVAILABLE: wiring
CURRENT: upload_protocol = wiring
Looking for upload port…
Use manually specified: COM10
Uploading .pioenvs\megaatmega2560\firmware.hex
avrdude: ser_open(): can’t open device “\.\COM10”: Das System kann die angegebene Datei nicht finden.
avrdude: ser_drain(): read error: Das Handle ist ung�ltig.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: Das Handle ist ung�ltig.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
*** [upload] Error 1
[ERROR] Took 3.51 seconds
- Linter
Severity Provider Description Line
Git
GitHub
Initialize a new project directory with a Git repository
Create repository
My platformio.ini
[env:megaatmega2560]
board = megaatmega2560
upload_port = COM10
upload_flags = -P$UPLOAD_PORT
edit 2:
i add now upload_flags
and get this messages
Assembler messages:
Fatal error: can’t create .pioenvs\megaatmega2560\FrameworkArduino\WInterrupts.c.o: No such file or directory
*** [.pioenvs\megaatmega2560\FrameworkArduino\WInterrupts.c.o] Error 1
Assembler messages:
Fatal error: can’t create .pioenvs\megaatmega2560\FrameworkArduino\WMath.cpp.o: No such file or directory
*** [.pioenvs\megaatmega2560\FrameworkArduino\WMath.cpp.o] Error 1
Assembler messages:
Fatal error: can’t create .pioenvs\megaatmega2560\FrameworkArduino\abi.cpp.o: No such file or directory
*** [.pioenvs\megaatmega2560\FrameworkArduino\abi.cpp.o] Error 1
Assembler messages:
Fatal error: can’t create .pioenvs\megaatmega2560\FrameworkArduino\WString.cpp.o: No such file or directory
*** [.pioenvs\megaatmega2560\FrameworkArduino\WString.cpp.o] Error 1
