Hey together,
I am creating a project to control and measure the temperature and humidity in my terrariums using an Arduino Uno. I have a lot of code by now and suddenly the arduino crashes in the setup routine.
Here is the output of the Serial:
imanuel@imanuel-inspiron ~/P/terrarium-measure-and-control> pio device monitor
--- Available ports:
--- 1: /dev/ttyACM0 'Goodix Fingerprint Device'
--- 2: /dev/ttyUSB0 'USB2.0-Serial'
--- Enter port index or full name: 2
--- Miniterm on /dev/ttyUSB0 9600,8,N,1 ---
Init display
Create epd
Create paint
Init epd
Clear frame memory
Set width an␀
This is the code of the setup routine:
Serial.begin(9600);
Serial.println(F("Init display"));
display->setup();
display->clear();
display->displayText(F("Initializing..."), 0);
Serial.println(F("Init clock"));
clock->setup();
Serial.println(F("Init humidity sensor"));
humiditySensor->setup(2);
Serial.println(F("Init dimmer"));
dimmer->setup(3);
Serial.println(F("Init temperatures"));
coldSideThermometer->setup(5, 0);
hotSideThermometer->setup(5, 1);
Serial.println(F("Init relay"));
relay->setup(6);
Serial.println(F("Init sender"));
sender->setup(A0, A1);
display->clear();
auto ip = sender->getIp();
display->displayTextTopRight(ip);
It does run through though, if I uncomment the following lines:
clock->setup();
The code inside the functions is as follows, for the clock->setup method
#include <RTClib.h>
auto rtc = new RTC_DS3231();
rtc->begin();
In the method sender->setup the code is as follows:
#include <SoftwareSerial.h>
#include <EEPROM.h>
#include <eeprom/EEPROMAccess.h>
#include "Sender.h"
Serial.println(F("Init ESP8266"));
EEPROM.begin();
auto serial = new SoftwareSerial(txPin, rxPin);
esp8266 = new ESP8266(*serial);
auto ssid = EEPROMAccess::readString(0);
auto passphrase = EEPROMAccess::readString(34);
esp8266->setOprToStationSoftAP();
esp8266->joinAP(ssid, passphrase);
esp8266->enableMUX();
esp8266->startTCPServer(8080);
esp8266->setTCPServerTimeout(10);
The packages I have installed have the following ids:
- 64
- 19
- 31
- 54
- 83
- 127
Can someone help me?
Greetings Knerd
