Arduino 8266 not working with pio 4.3.1
Yeah that special framework version and GCC9 are working perfectly.
Can you try the following platformio.ini:
[env:esp12e]
platform = espressif8266
board = esp12e
upload_speed = 3000000
monitor_port = /dev/cu.SLAB*
upload_port = /dev/cu.SLAB*
build_flags =  -fexceptions  -Teagle.flash.4m1m.ld -std=c++14
build_unflags = -fno-exceptions -std=c++11
platform_packages =
	framework-arduinoespressif8266 @ https://github.com/earlephilhower/Arduino.git#gcc9.1
	toolchain-xtensa @ https://github.com/maxgerhardt/xtensa-lx106-elf/raw/master/xtensa-lx106-elf-darwin64-9-2-0.zip
(already adapted for Darwin x64 targets)
with the code
#include <string>
#include <regex>
void setup()
  Serial.println("Hello world!");
  Serial.flush();
  delay(1000);
  std::regex rgx("^(.*)\\.(htm|html)");
  std::smatch matches;
  std::string url = "/index.html";
  Serial.println("Before regex_search()");
  Serial.flush();
  delay(1000);
  bool res = std::regex_search(url, matches, rgx);
  Serial.printf("\n\nmatch = %d search=%d, results=%d\n", res? 1: 0, res, matches.size());
void loop()
  delay(10000);
should produce
match = 1 search=1, results=3<\n>
Hello world!
