Minimal app consisting of
const int ledPin = 2;
int intSpeed;
// the setup() method runs once, when the sketch starts
// initialize the digital pin as an output.
pinMode(ledPin, OUTPUT);
int intIn=50;
intSpeed = int((float(intIn) / 100) * 255);
Serial.println("Start");
// the loop() methor runs over and over again,
// as long as the board has power
digitalWrite(ledPin, HIGH); // set the LED on
delay(50);
digitalWrite(ledPin, LOW); // set the LED on
delay(50);
for(int i=1;i<4;i++) {
delay(220); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
delay(i*1000); // wait for a second
Serial.println("loop");
Compiles fine, seems to load OK and when I press the reset button. I see the string of unprintable characters in the serial monitor but no output from the program. I have tried about 5 differetnt applications including a simple web server, the basic OTA program, my own lamp controller, etc. The web server doesn’t appear to be functional and none of the programs produce any usable output on the serial monitor. Here’s the platform.ini file
[env:esp01_1m]
platform = espressif8266
board = esp01_1m
lib_extra_dirs = ~/Documents/Arduino/libraries
I’m missing something really basic, I think.
So I pulled the esp8266 and plugged in another 8266 that had been previously programmed with an HTTP server program.
While it appears to load the new program
Writing at 0x00024000... (76 %)
Writing at 0x00028000... (84 %)
Writing at 0x0002c000... (92 %)
Writing at 0x00030000... (100 %)
Wrote 296560 bytes (212314 compressed) at 0x00000000 in 18.7 seconds (effective 126.7 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
======== [SUCCESS] Took 21.84 seconds ========
When I start the serial monitor and press the reset button on the chip, I get the garbage string followed by a “HTTP server started” message which tells me that the program that is running is what was there before.
I’d sure like help on this. This is the platformio.ini file for the other part:
[env:esp12e]
board = esp12e
The computer is running Mint 19, I downloaded the udev rules and restarted udev.
Thanks for any help,
Jim.
