There appears to be a bug in the esp-idf related to using the esp32 as an access point. They claim it has been fixed in v3.2 of the idf but I note that the current platformio support for esp32 is still using ESP-IDF framework to v3.1.3
Is there any timeline on when v3.2 will be available in platformio? My current project requires the esp32 act as an access point but right now you can’t even connect due to the exception.
Probably as soon as v3.2 is offically released. At the moment the most current ESP-IDF-release is v3.1 and the v3.2 in the ESP-IDF repo is “only” in beta status.
If you need the fix ASAP you could trace down the exact commit in the ESP-IDF repo that fixes it and copy the fixes to your local files…
