Another unhandled exception
I found a BME680 example that uses different libraries than the one I used yesterday the raised the unhandled exception error.
The code worked. I was getting sensor data in the serial monitot.
Then I added the 1306 OLED. It compiled and uploaded just fine, and then kerplooey:
Rebooting…
�␄r�␅���SB��UR��TS�@bץƧ�BME680 async test
Guru Meditation Error: Core 1 panic’ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4000c46c PS : 0x00060f30 A0 : 0x800d1b8c A1 : 0x3ffb1f60
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000400 A5 : 0x00000000
A6 : 0x00000001 A7 : 0x00000040 A8 : 0x00000001 A9 : 0x3ffb1ef0
A10 : 0x00000000 A11 : 0x000000fe A12 : 0x00000001 A13 : 0x3ffc017c
A14 : 0x00000004 A15 : 0x00000002 SAR : 0x0000001c EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x0000003f
Backtrace: 0x4000c46c:0x3ffb1f60 0x400d1b89:0x3ffb1f70 0x400d0f84:0x3ffb1f90 0x400d4f39:0x3ffb1fb0 0x40088a59:0x3ffb1fd0
Das Code:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_GFX.h> //Libraries for the OLED and BMP280
#include <Adafruit_SSD1306.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_SSD1306 display(128, 64, &Wire, 8); //Declaring the display name (display)
Adafruit_BME680 bme; // I2C
//Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
void setup()
  Serial.begin(9600);
  bme.begin();
  while (!Serial)
  Serial.println(F("BME680 async test"));
  if (!bme.begin())
    Serial.println(F("Could not find a valid BME680 sensor, check wiring!"));
    while (1)
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
void loop()
  display.clearDisplay();
  // Tell BME680 to begin measurement.
  unsigned long endTime = bme.beginReading();
  if (endTime == 0)
    Serial.println(F("Failed to begin reading :("));
    return;
  Serial.print(F("Reading started at "));
  Serial.print(millis());
  Serial.print(F(" and will finish at "));
  Serial.println(endTime);
  Serial.println(F("You can do other work during BME680 measurement."));
  delay(50); // This represents parallel work.
  // There's no need to delay() until millis() >= endTime: bme.endReading()
  // takes care of that. It's okay for parallel work to take longer than
  // BME680's measurement time.
  // Obtain measurement results from BME680. Note that this operation isn't
  // instantaneous even if milli() >= endTime due to I2C/SPI latency.
  if (!bme.endReading())
    Serial.println(F("Failed to complete reading :("));
    return;
  Serial.print(F("Reading completed at "));
  Serial.println(millis());
  Serial.print(F("Temperature = "));
  Serial.print(bme.temperature);
  Serial.println(F(" *C"));
  Serial.print(F("Pressure = "));
  Serial.print(bme.pressure / 100.0);
  Serial.println(F(" hPa"));
  Serial.print(F("Humidity = "));
  Serial.print(bme.humidity);
  Serial.println(F(" %"));
  Serial.print(F("Gas = "));
  Serial.print(bme.gas_resistance / 1000.0);
  Serial.println(F(" KOhms"));
  Serial.print(F("Approx. Altitude = "));
  Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
  Serial.println(F(" m"));
  Serial.println();
  display.setCursor(0, 0); //Oled display, just playing with text size and cursor to get the display you want
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.print("Temp");
  display.setCursor(0, 18);
  display.print(bme.temperature, 1);
  display.setCursor(50, 17);
  display.print("C");
  display.setCursor(65, 0);
  display.print("Pres");
  display.setCursor(65, 10);
  display.print(bme.pressure, 0);
  display.setCursor(110, 10);
  display.print("hPa");
  display.setCursor(65, 25);
  display.print("Hum");
  display.setCursor(90, 25);
  display.print(bme.humidity, 0);
  display.setCursor(110, 25);
  display.print("m");
  display.display();
  delay(2000);
I added these two libraries and the display lines.
Trying to use the WeMos:
[env:wemos_d1_mini32]
board = wemos_d1_mini32
Anything here look familiar? I mean, in relation to your devices etc?
https://www.google.com/search?q=Guru+Meditation+Error%3A+Core+1+panic’ed+(StoreProhibited).&client=tablet-android-samsung-nf-rev1&sourceid=chrome-mobile&ie=UTF-8
Cheers,
Norm.
Looks like something is reading from an uninitialised pointer? Address zero is usually NULL.
Cheers,
Norm.
IMG_8701'
I removed all the OLED text and put it back in stepwise.
Now it’s time to turn this into a BLE peripheral device, transmit those variable values.
