Processing esp32cam (platform: espressif32; board: esp32cam; framework: arduino)
Removing unused dependencies…
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio_main_.py”, line 102, in main
File “C:\Users\darsh.platformio\penv\lib\site-packages\click\core.py”, line 1130, in call
File “C:\Users\darsh.platformio\penv\lib\site-packages\click\core.py”, line 1055, in main
rv = self.invoke(ctx)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\cli.py”, line 70, in invoke
return super().invoke(ctx)
File “C:\Users\darsh.platformio\penv\lib\site-packages\click\core.py”, line 1657, in invoke
File “C:\Users\darsh.platformio\penv\lib\site-packages\click\core.py”, line 1404, in invoke
File “C:\Users\darsh.platformio\penv\lib\site-packages\click\core.py”, line 760, in invoke
File “C:\Users\darsh.platformio\penv\lib\site-packages\click\decorators.py”, line 26, in new_func
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\run\cli.py”, line 145, in cli
process_env(
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\run\cli.py”, line 198, in process_env
result[“succeeded”] = EnvironmentProcessor(
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\run\processor.py”, line 81, in process
install_project_env_dependencies(
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\commands\install.py”, line 132, in install_project_env_dependencies
_install_project_env_libraries(project_env, options),
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\commands\install.py”, line 204, in _install_project_env_libraries
_uninstall_project_unused_libdeps(project_env, options)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\commands\install.py”, line 280, in _uninstall_project_unused_libdeps
lm.uninstall(spec)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\manager_uninstall.py”, line 29, in uninstall
return self._uninstall(spec, skip_dependencies)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\manager_uninstall.py”, line 34, in _uninstall
pkg = self.get_package(spec)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\manager\base.py”, line 263, in get_package
spec = self.ensure_spec(spec)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\manager\base.py”, line 133, in ensure_spec
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\meta.py”, line 183, in init
self._parse(self.raw)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\meta.py”, line 290, in _parse
raw = parser(raw)
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\meta.py”, line 315, in _parse_requirements
self.requirements = tokens[1].strip()
File “C:\Users\darsh.platformio\penv\lib\site-packages\platformio\package\meta.py”, line 230, in requirements
else semantic_version.SimpleSpec(str(value))
File “C:\Users\darsh.platformio\penv\lib\site-packages\semantic_version\base.py”, line 647, in init
self.clause = self._parse_to_clause(expression)
File “C:\Users\darsh.platformio\penv\lib\site-packages\semantic_version\base.py”, line 1043, in _parse_to_clause
return cls.Parser.parse(expression)
File “C:\Users\darsh.platformio\penv\lib\site-packages\semantic_version\base.py”, line 1063, in parse
raise ValueError(“Invalid simple block %r” % block)
ValueError: Invalid simple block ‘’
Verify that you have the latest version of PlatformIO using
pip install -U platformio
command -
Try to find answer in FAQ Troubleshooting section
Redirecting... -
Report this problem to the developers
Issues · platformio/platformio-core · GitHub
